Stanley Bedrock 607
« back to Hand Tools forum
Forum topic by James Gallo posted 09-30-2016 06:07 PM 1360 views 0 times favorited 17 replies Add to Favorites Watch
View James Gallo's profile
James Gallo
68 posts in 2078 days
09-30-2016 06:07 PM
Hi all,
I purchased a lot of 7 hand planes off of craigslist for $20, and have begun restoring and trashing them as needed. I came across a Stanley Bedrock 607, and as I was preparing to reassemble it, I thought I would do a little research on the bedrock design. All of the info I found state that the frog locates by 2 pins that are on the body of the plane. However, my 607 does not have the pins, it locates and adheres to the body with 2 screws instead. From what I can tell, this is a very early version of the plane, as it has the 3 line logo on the lever cap.Has a previous owner messed with this plane and replaced the pins with screws?
The plane otherwise seems to be in excellent condition, with only very slight surface pitting on one side, and some of the japanning missing.
I want to return this plane to original condition and use it, but do not want to have a frankenplane. Thanks for any advice.
Sent from my iPad using Tapatalk
-- Jg, Pittsburgh
17 replies so far
View bobasaurus's profile
bobasaurus
3407 posts in 3152 days
#1 posted 09-30-2016 06:19 PM
According to this type study:
http://www.antique-used-tools.com/brtypes.htm
the pin attachment of the frog only happened on type 5 (1911) and on. Yours might be an earlier type.
-- Allen, Colorado (Instagram @bobasaurus_woodworking)
View JayT's profile
JayT
5589 posts in 2179 days
#2 posted 09-30-2016 06:40 PM
You have very good example of a type 3 Bedrock. Types 1-4 all had the round sides and the frog attached with screws. What made them different from the Bailey line of the same era was the machined frog to base contact area and the adjustment screw at the rear of the frog. In 1911, Stanley added the frog adjustment screw to the Bailey line and changed the Bedrock design to flat sides and pin retention of the frog.
As far as I can see, all the parts and pieces are consistent with a type 3 Bedrock, so rest assured you do not have a Frankenplane. I have a whole user collection of early round sided Bedrocks, mostly type 4’s with a couple type 3’s thrown in, and love them. Tune it up and put it back to use.
James Gallo
#3 posted 09-30-2016 07:38 PM
Thanks so much for the replies and link. I’m not familiar with the type 1,2,3,etc. Are certain type numbers better or worse than others? Also, how can I tell the manufacture date of my plane?
-- Jg, Pittsburgh
View ColonelTravis's profile
ColonelTravis
1756 posts in 1862 days
#4 posted 09-30-2016 07:41 PM
For jealously purposes only, was that Bedrock in that lot of 7 for $20?
View JayT's profile
JayT
#5 posted 09-30-2016 08:07 PM
All the “types” do is give a range of manufacture dates based on the features and marking on the plane. As far as one type being better or worse, the answer is “depends”. For Bedrocks, they are all good planes. Types 1-4 are all basically the same design with just small changes in what numbers are incorporated into the castings (7 vs 607 or patent dates or the lever caps, for example) and the logos on the irons. Types 5-11 all have similar features and design when compared to each other, as well.
As a type 3 Bedrock, your plane was manufactured between 1900-1908. Just go to the type study linked and compare the features of your plane to the lists under each type. It’s tough to narrow down a specific date any more than that. Sometimes you come across a plane that has characteristics of a couple types. If the parts are all original, that can give a clue that it was manufactured close to the crossover date of those two types. For instance, a plane with a type 4 body and lever cap, but an iron with a logo like a type 3 was probably made around 1908.
Is a type 5 better than a type 3? Well, they are two different designs and both are good planes. Some people prefer the later, flat sided types, so will pay more for them, but that doesn’t really make them “better”, just more desirable. Personally, I don’t consider the frog adjustment mechanism to be that important. Once a frog is set, I don’t move them, so wouldn’t want to pay extra for the feature.
Now, when you get into lines other than the Bedrocks, such as the Stanley Bailey, there is definitely a drop off in quality in the later types. Not that a later Bailey can’t be a good user, but the odds are better if you get a type that was made between the World Wars. Conversely, some of the early Baileys, while well made and collectible, aren’t quite as user friendly as far as features. For instance, the earliest ones don’t have a lateral adjustment lever, so that adjustment had to made with a hammer. To me, that is a very important feature, and while the plane is good quality, it’s more difficult to use, so I would not want a user of those types.
Also keep in mind that type studies were done after the fact as a way to try and date the tools. The manufacturers didn’t care at the time and just used up stocks of parts that fit each other to have a complete tool to sell.
James Gallo
#6 posted 09-30-2016 08:15 PM
Thanks Jay. You cleared up a lot of things for me!!!!
-- Jg, Pittsburgh
View Johnny7's profile
Johnny7
361 posts in 1058 days
#7 posted 09-30-2016 08:58 PM
You’re making me nervous—move that plane casting away from the edge of the tablesaw top!
Smitty_Cabinetshop
15283 posts in 2586 days
#8 posted 09-30-2016 09:00 PM
Like Col. said, if you got that bedrock 607 in the lot for $20, it’s You Suck territory for sure. Excellent pick-up, congrats to you!
View TheTurtleCarpenter's profile
TheTurtleCarpenter
1032 posts in 1034 days
#9 posted 09-30-2016 10:05 PM
Don’t comment back on the $20 question please,,,,,,,,,Its Friday and I don’t care for the Monday blues
-- "Tying shoelaces was way harder than learning to Whistle",,,,,member MWTCA area K. Kentucky
James Gallo
#10 posted 10-01-2016 09:28 PM
Yep. $20. I tried to pass on the lot because he wanted $55 and he didn’t want to split them. There was a stanley no 5 in the group that I wanted, but didnt know what a 607 zctually was at the time. So i walked back to my car and he follows me and offers all of them for $30. I passed again. He was about to leave, but stopped and asked ” how about $20 for them all?” I bit and now I’m glad I did.
-- Jg, Pittsburgh
View Tim's profile
Tim
3784 posts in 1929 days
#11 posted 10-01-2016 11:31 PM
Now you’re just rubbing it in, hah!
View Don W's profile
Don W
18686 posts in 2535 days
#12 posted 10-02-2016 12:31 AM
$20 Bedrock. I got mine for $18. We’re in the same territory!
View theoldfart's profile
theoldfart
9619 posts in 2419 days
#13 posted 10-02-2016 01:15 AM
I was happy for a 608 & 604 for $75, you beat that by a mile.
-- "With every tool obtained, there is another that is needed" DonW ( Kevin )
View TheFridge's profile
TheFridge
9249 posts in 1454 days
#14 posted 10-02-2016 01:16 AM
Hell. I was has with a plain ol #5 for 30
View diverlloyd's profile
diverlloyd
2664 posts in 1825 days
#15 posted 10-02-2016 02:29 AM
Well I feel I got my flat side corrugated bedrock for $5 at auction could have got it cheaper but I always start out at $5 on tools. I will just say congrats on the planes I love my bedrock it’s my go to plane. $20 for the lot is outstanding very nice and once you get a sharpening method that works for you you will enjoy them.
