Sanding disk on table saws
Forum topic by markx posted 06-24-2010 07:30 AM 1374 views 0 times favorited 7 replies Add to Favorites Watch
View markx's profile
markx
2 posts in 2938 days
06-24-2010 07:30 AM
Anyone use sanding disks on their table saws? I have an old Delta contractor saw that still runs well. If I use it as a sander, will I be creating lateral stresses on the bearings? Is using a table saw as a sander a good idea?
What do you think? The link below shows an example of what I am talking about.
http://www.amazon.com/Table-Saw-Sanding-Disk-SANDING/dp/B001D6MF9Y/ref=sr_1_14?ie=UTF8&s=hi&qid=1277356765&sr=1-14
7 replies so far
View childress's profile
childress
841 posts in 3542 days
#1 posted 06-24-2010 07:58 AM
I use one quite a bit. Makes sanding edges fast…Of course you could invest in The Final Cut instead and not have to change anything out!
-- Childress Woodworks
View richgreer's profile
richgreer
4541 posts in 3074 days
#2 posted 06-24-2010 02:48 PM
I have used a sanding disk on my ShopSmith which is sort of like using it on a TS.
View mtkate's profile
mtkate
2049 posts in 3325 days
#3 posted 06-24-2010 03:09 PM
I have a sanding disk that I use from time to time on the table saw – I find it “ok” but I know it’s not as good or flexible as a dedicated sanding machine. I use it for rough stuff then go to my POS or by hand pretty quickly.
View MICHAEL CAMPASANO's profile
MICHAEL CAMPASANO
53 posts in 3798 days
#4 posted 06-24-2010 04:47 PM
I did use it on my table saw but got tired of removing the saw blade and putting the sanding disk on the arbor so I bit the bullet an purchased a stand alone Belt and sanding disk combination tool. It is so much easier.
Mike
-- never enough time in a day so use it well
View MrsN's profile
MrsN
986 posts in 3526 days
#5 posted 06-24-2010 05:06 PM
Maybe it is just me, but wouldn’t having the sanding disk in the middle of the table saw table be aquward to use. My stand alone belt/disk sander lets me get pretty close and personal with the disk, I cant get that close to my saw blade. Maybe I just have short arms or something.
MrsN
markx
#6 posted 06-24-2010 07:14 PM
Thanks for the feedback so far. This is a great list. 8-)
View Knothead62's profile
Knothead62
2584 posts in 2961 days
#7 posted 06-24-2010 09:39 PM
I got one at Woodcraft and love it. The TS top has slots in it so I drilled two holes in a 1X3, got some 1/4-20 screws, wing nuts, and homemade washers from 1-/4X1 mild steel. I bolt the board to the top, square it up and sand away. I’ve used it many times and it does a great job. It may be easier to buy a sander as Michael C. stated, but I’m cheap!
