Replacing the Delta 40-560 motor
« back to Scrollsawing forum
Forum topic by mattswier posted 09-29-2016 11:42 AM 565 views 0 times favorited 1 reply Add to Favorites Watch
View mattswier's profile
mattswier
1 post in 660 days
09-29-2016 11:42 AM
Topic tags/keywords: scrollsaw delta delta scrollsaw 40-560 question scroll saw
The stock 2 speed motor on my 16” Delta Scroll saw recently stopped working. It gets really hot and stops after 5 minutes of use until it cools down.
I went onto eBay and purchased the exact motor, new old stock (NOS) and installed the new motor using the Delta wiring diagram. The new motor only operates at appox. 1/4 to 1/3 of the speed of the original motor. When I put the original motor back in, it fires right up at the correct operating speed. After contacting the dealer on eBay, he promptly sent out another NOS motor….after installing this second one, it does the same thing….only operates at 1/4-1/3 of the speed it’s supposed to.
Any ideas?
1 reply so far
View wichman3's profile
wichman3
67 posts in 676 days
#1 posted 12-10-2016 05:04 PM
I have the same saw. Did you check the motor speed figures on the new motors? 1725/850 is what mine lists, yours?
If you are comfortable with disassembling the motor, take it apart; clean the commutator, scrape the brushes, and lubricate the bearings (use a Teflon grease). reassemble and see if that solves the overheating problem.
While you are at it, make sure all the pivot points are well lubricated, anything that is binding will contribute to the overheating.
