Smaller Diameter Blades on Saw Stop?
Forum topic by Dan posted 09-29-2016 12:50 AM 1130 views 0 times favorited 20 replies Add to Favorites Watch
View Dan's profile
Dan
650 posts in 1768 days
09-29-2016 12:50 AM
Hello, I want to run a 6” diameter fret slotting blade in my Saw Stop. Can anyone share a method to accomplish that?
Thanks
-- Dan
20 replies so far
View marc_rosen's profile
marc_rosen
129 posts in 3057 days
#1 posted 09-29-2016 01:20 AM
Hi Dan,
From what I’ve read in the manual I don’t think it is possible but I wonder if you were to try to override the safety feature (Bypass Mode) if it would then run. I don’t know if the saw will allow you to go into bypass if it still senses a brake cartridge too far away from a blade.
That’s a question for Sawstop, but they may not tell you it’s possible if it could lead to some type of liability issue.
Let us know if you do try Bypass, regardless of its result. Marc
-- Windsurfing, Woodworking, Weaving, and Woodducks. "Most woodworkers are usually boring holes"
View soapmaker's profile
soapmaker
48 posts in 1557 days
#2 posted 09-29-2016 01:39 AM
From my use I would have to say that is not possible. Even with the override the blade has to be the correct size, a 10 inch for the standard cartridge and an 8 inch for the dado cartridge. I would like the ability to do this but it is outside of its abilities, short of altering something in a way that would void warranties and such. Is there no fret slotter in an 8 inch?
View DrDirt's profile
DrDirt
4418 posts in 3618 days
#3 posted 09-29-2016 01:39 AM
put the blade in it and see if it runs.
everything else is guessing – - the brake isn’t going to be triggered, but like marc said, the bypass is likely necessary for it to override the checks it does on power-up
View Dan's profile
Dan
#4 posted 09-29-2016 02:00 AM
Marc and Soapmaker, I know there are guys who have figured out workarounds, I just was wondering if they did it with minimal disruption to the saws integrity. After reading the manua I also think that it can’t be done under standard procedures. But as DrDirt suggests I’ll give it a shot to see for myself.
I ordered the fret slot blade from StewMac without realizing it was only 6”.
-- Dan
4830 posts in 2369 days
#5 posted 09-29-2016 10:55 AM
I don’t see how you could do it, even on bypass it has to sense the blade. I imagine the “workarounds” to which you refer have something near the cartridge to make the saw think all is good. That same something could get caught or come loose or cause some other problem; overall sounds like a bad plan.
View OggieOglethorpe's profile
OggieOglethorpe
1276 posts in 1986 days
#6 posted 09-29-2016 11:46 AM
It can be done! No bypass needed… I figured this out about 3 years ago.
I run 7-1/4” 1/16” kerf blades by using a shop-made 1/8” thick aluminum “liner” mounted to the inside face of the dado insert. The liner is held in place with aluminum #8 FH screws that install into holes drilled and tapped in the brake shoe. I can remove two screws and go back to 8” dados in seconds. It’s not coming off on it’s own…
I use aluminum screws thinking steel might not allow the blade to properly cut the brake during a firing. Screws in general, over tape, hot glue, etc… carry conductivity out to new face to allow the machine to pass POST. The blades I’m typically using are 60T Diablo circular saw blades, for slicing bandings and veneers, as well as narrow grooves.
With a thicker insert, you may be able to get to your size blade. If you’re careful during design, you can come up with an insert that will let you install it with little to no gap adjustment. An easy source of aluminum screws are hobby shops that carry lots of r/c car stuff. The aluminum came from a big box home center.
This technique is not endorsed by SawStop, and I’m sure it would void the cartridge warranty, if not the entire saw warranty.
View ohtimberwolf's profile
ohtimberwolf
738 posts in 2228 days
#7 posted 09-29-2016 11:59 AM
oggie, how about a picture, that would be nice for dummies like me. :)
-- Just a barn cat, now gone to cat heaven.
View Dan's profile
Dan
#8 posted 09-29-2016 12:39 PM
Oggie, Thanks for sharing. I am in Timberwolfs’ camp though, a picture would be really helpful. Questions like; do you remove the tape that is adhered to the cartridge etc. I could buy a mini table saw for about the price of a cartridge if I was to try it and screw up a brake cartridge. (or two or three)
Fred, thanks for your response.
-- Dan
OggieOglethorpe
#9 posted 09-29-2016 06:20 PM
Here it is…
By viewing these photos you accept all responsibility for any damage to your machine, or personal injury, resulting from modifying your equipment. I make no claims as to the safety of this modification, or it’s suitability for your skill set, experience level, or specific machine. You use this information at your own risk.
ohtimberwolf
#10 posted 09-29-2016 07:41 PM
Thanks oggie, nice pictures and very needed, well stated, disclaimer. larry
OggieOglethorpe
#11 posted 09-29-2016 07:48 PM
All that said, I’ll bet the very first commercially available woodworking machine was modded 60 minutes after it was purchased. ;^)
Just like motorsport being born the moment the second car came into existence…
MrUnix
6201 posts in 2075 days
#12 posted 09-29-2016 07:59 PM
Save yourself the hassle and find a dirt cheap little used portable universal screamer saw on CL for $20-$30 or so – and dedicate it to cutting your fret slots.
#13 posted 09-29-2016 08:25 PM
While I have several thoughts, I’ll keep them to myself and wish you the best as you try and solve your problem.
View Redoak49's profile
Redoak49
3017 posts in 1864 days
#14 posted 09-29-2016 08:45 PM
Well…I have several thoughts…some not good. I would be extremely careful. If the brake is set off and the brake slams into a thin blade, I fear you could have shards of metal flying.
I would not do it but to each their own and Good Luck.
OggieOglethorpe
#15 posted 09-30-2016 11:04 AM
Anyone who has doubts should clearly not use this information. A few clarifying details though…
This is not a mod for general, everyday use. It is to accomplish a specific set of tasks with a skilled operator.
- When I’m using the circular saw blade, there is a fresh sheet of 3/4” MDF Mag Switched to the saw table, with a zero clearance slot cut fresh at the start of the session. I’m cutting 1/16” wide strips of material from stock less than 1/2” thick, more often 1/4”, so a sloppy kerf would ruin the work.
- My strips are cut between the blade and fence with a spot-made hooked MDF push strip. The device pushes both sides of the cut clear to the back, where an air nozzle with a about a 20 PSI flow blows the cut off to the right.
- I use an Excalibur overarm guard. The push rig slides right under it, across the MDF. Yet another reason why splitter mounted guards stink.
A 1/16” slot in a table sheet that weighs ~ 20 pounds without the Mag Switches holding them down, a purpose-made push device, an off cut light enough to be puffed away, and a proven and industry respected guard… With this in mind, the chance of anything inside the saw getting outside the saw or anywhere near the operator is low enough that I’m perfectly comfortable.
The OP is needing to cut fret slots. In other words, accurate, shallow, thin kerfs… A simple sled to carry the work will accomplish many of the safety enhancements added by my extra parts.
