bending wood
Forum topic by doyoulikegumwood posted 1971 days ago 592 views 0 times favorited 5 replies Add to Favorites Watch
View doyoulikegumwood's profile
doyoulikegumwood
384 posts in 2164 days
1971 days ago
ok for a long time now i have wanted to build a fram drum wich is nothing more then a hoop thats about 4” wide and around 18” in diamater heres my question to you if i were to bend say 1/8” thick by 4” tall by 18” long pieces around a form or into a form would steaming the wood still be nessasary .
-- I buy tools so i can make more money,so ican buy more tools so I can work more, to make more money, so I can buy more tool, so I can work more
5 replies so far
34370 posts in 2573 days
#1 posted 1971 days ago
Well the wood if only 18” long wouldn’t bend. But I think you meant it would be about 60” long and make a loop with a 18” diameter.
To me that’s not a lot of wood to waste. I’d try resawing and give it a bend. One plank should give you about 6 slices. That diam is almost the size that is used on Shaker boxes and they bent them in Hot Water. But you’d need a 60” long hot water tank and a couple of hot plates to get it hot and keep it hot. Or steam.
The shaker boxes are being bent around a 6” radius circle. or so. But usually thinner wood. But it is thicker in larger boxes.
View Sawdust2's profile
Sawdust2
1467 posts in 2260 days
#2 posted 1971 days ago
You might try soaking it in water and putting it in the microwave.
View SPalm's profile
SPalm
4120 posts in 2054 days
#3 posted 1971 days ago
My limited bending has taught me a few things:
It is the heat that helps you bend wood. It loosens the fibers in the wood and makes them more pliable. When it cools, they will become not so pliable again and thus remain bent. Steam is an easy way to apply high heat that will penetrate the wood, but any heat will do it. Air dried wood will steam bend a lot easier than kiln dried wood, oak better than cherry, etc.
But it will be hard to apply heat to a 60 inch board, so if I had to do it, I would use a glue-up of resawed planks. By gluing the plies together, they will remain bent when the glue dries. If you just bend a single board, without steam or ply glue-up, it will constantly try to spring back to straight and put a lot of tension on the joint.
Steve
-- -- I'm no rocket surgeon
View patrick m's profile
patrick m
197 posts in 1985 days
#4 posted 1970 days ago
doyoulikegumwood, hey check out some boat building books . I subscribe to Wooden Boat. There are often articles on a few different ways I’ve seen to bend wood … If you go chemical, just wear that resporator… cough…cough…... patrick, woodnut.
-- PJM.`·.¸¸.·´¯`·.¸¸.·´¯`·.¸ ><((((º> ""BY HAMMER AND HAND ALL ARTS DO STAND""1785-1974 nyc Semper Fi, Patrick M
doyoulikegumwood
#5 posted 1970 days ago
thanks guys this is helpfull my plan is to use plys i just wasnt sure if the steam or boiling was totaly nessasary
