Gun case door help needed
« back to Joinery forum
Forum topic by TechTeacher04 posted 09-28-2016 03:36 PM 672 views 0 times favorited 10 replies Add to Favorites Watch
View TechTeacher04's profile
TechTeacher04
389 posts in 1678 days
09-28-2016 03:36 PM
Topic tags/keywords: question tip
I have designed a single door gun cabinet to display a Hawken Flintlock Rifle he built and shot at a Bicentennial Celebration. For security we have chosen Lexan as opposed to temptered glass and to help lighten the door.
My question is what is the best way to attach the lexan to the door? I am using solid hard maple for the construction. I am used to making captive panel through cope and stick or tongue and grove joinery. I plan to spray pre-cat lacquer on it, but am concerned about masking off the lexan. This is my first “glass” door, I have seen one some cabinets a cleat is used to hold in the panel of glass, however I am concerned about the security of this being contingent on the fasteners.
10 replies so far
View jbay's profile
jbay
2678 posts in 1046 days
#1 posted 09-28-2016 03:47 PM
It’s either captive or non captive.
You can make it non captive and glue the retaining strips in after finishing the door. Don’t finish the area you will be gluing to.
Or make it captive and leave the masking on then razor blade the masking off after finishing the door, this will leave the thin strip of masking inside the frame though.
I would do the retaining strips after finishing.
One word of thought, If I wanted the gun I would tear the door right off the cabinet, your not going to stop somebody that really wants it no matter what you do… (insurance)
View JBrow's profile
JBrow
1366 posts in 1067 days
#2 posted 09-29-2016 12:06 AM
TechTeacher04,
The time may come when the Lexan or whatever else may be used would have to be replaced. A fully captured panel would make replacing the clear panel extremely difficult. Continuous glass stays screwed in place would make both finishing the door and replacing the clear panel much easier. The number, length, and placement of the screws, the thickness of the door, and the glass retaining strips’ material and thickness all work together and could either strengthen or weaken the security of the clear panel.
I am not familiar with physical properties of Lexan, tempered glass, or impact resistant glass as these properties relate breakage. But I am surprised that Lexan is selected. So it is really more impact resistant than tempered or impact resistant glass?
I agree with jbay. A thief willing to risk breaking glass could defeat the door’s locking mechanism or hinges with a pry bar or simply remove the cabinet.
TechTeacher04
#3 posted 09-29-2016 12:02 PM
After discussions with the glass/plexi/lexan supllier and the customer we chose Lexan (polycarbonate) due to its impact resistance and reduced weight as compared to tempered glass.
View jbay's profile
jbay
#4 posted 09-29-2016 02:57 PM
- JBrow
Lexan (polycarbonate), is pretty much unbreakable.
You can smash it all you want with a hammer and only dent it.
Tech:
They do make a product called “Marguard”, it’s a polycarbonate with a surface coating that makes it more abrasion resistant. Holds up better to light scratching and everyday cleaning. For what your making, it would be a good consideration although like anything it’s more expensive.
Here is another one called MR-10
View bonesbr549's profile
bonesbr549
1576 posts in 3214 days
#5 posted 09-29-2016 03:34 PM
If it were me I would not lock that thing in and provide no way to ever change because of an “oh crap” moment.
Go ahead and do a cope-n-stick but on the back side use a dado router bit with bearing and do a (normally) 3/8’s dado to take out the back side (after glueup) You will have to 90 those corners because with a chisel as that router bit will leave a round corner. A good sharp chisel will take care of that quick.
Then take some 3/4 stock and do a profile of your choice on the long edges and run 1/4 dado down the center. Rip the pieces of and you have some qtr round strips.
Custom fit those with miters and pin them in with spot glue in middle and close to the edge. If they need replacing they can be popped out. I generally make enough extra to give someone for just in case.
Heres one on a hutch I did. Don’t paint yourself in a corner so to speak :)
https://flic.kr/p/dRBABR
View Cooler's profile
Cooler
299 posts in 990 days
#6 posted 09-29-2016 04:31 PM
I would use quarter round stock to lock the lexan in from behind, mitering the corners and pinning with brass escutcheon pins.
Note: Clean the plastic infrequently with a very clean microfiber cloth. Wipe gently.
If you clean it infrequently it won’t scratch up for a long time.
-- This post is a hand-crafted natural product. Slight variations in spelling and grammar should not be viewed as flaws or defects, but rather as an integral characteristic of the creative process.
bonesbr549
#7 posted 09-29-2016 06:14 PM
Go ahead and do a cope-n-stick but on the back side use a dado router bit with bearing and do a (normally) 3/8 s dado to take out the back side (after glueup) You will have to 90 those corners because with a chisel as that router bit will leave a round corner. A good sharp chisel will take care of that quick.
Heres one on a hutch I did. Don t paint yourself in a corner so to speak :)
- bonesbr549
Found a door pic where I did the above. A little spacer block attached to base with carpet tape to make life easy.
View Kelly's profile
Kelly
2092 posts in 3091 days
#8 posted 09-30-2016 01:13 PM
My little brother needed a school project. He chose to build a display case for a generations old 30-30 Winchester. He asked me to help him design it. We came up with just a box that would mount horizontal on the wall. It would have a flip up, glass door, which would be etched with a scene of an elk stepping over a log.
I etched the glass for him and learned the teacher insisted he assemble the box door, then cut it on the saw to give him the door. I pointed out the problem of getting to the glass, if something went wrong.
Of course, the shop teacher knew better than the guy who played with wood and dealt with customers for a living. Sad. He cracked the glass bringing the cabinet home on the school bus.
View JAAune's profile
JAAune
1838 posts in 2463 days
#9 posted 09-30-2016 01:50 PM
I advise rethinking the captured part. Glass breaks and plastic scratches. Polycarbonate is pretty soft too.
Plus, the moment you install the cabinet some well-meaning person will come along and spray ammonia-based cleaner all over the door and wipe it down with the same cotton cloth used to dust the tv.
Cooler
#10 posted 09-30-2016 02:00 PM
- JAAune
I agree. The easy way is how my kitchen cabinets were built. The glass is held in with silicone adhesive (which failed once). I added screw in screen mounting clips: https://doitbest-weblinc.netdna-ssl.com/product_images/storm-and-screen-clip-1/211639/54f6f3d369702d60eb89211f/large_thumb.jpg?c=1472648460
