| Forum topic by Mike Kemper | posted 285 days ago | 3459 views | 0 times favorited | 19 replies | ![]() |
285 days ago |
I have a Craftsman 10” table saw that’s about that about 10 years old. The saw it self works great the fence is a different story. After pricing new saws I’m beginning to lean towards a new fence for the Craftsman. I’m sure there are some of you fellow LumberJocks out there that replaced there Craftsman fence with a new one, I could sure use your input |
285 days ago |
Hey Mike.. Ironically I just replaced the fence on my 1952 Craftsman 10” tilt-arbor table saw that I had recently restored. I was going to make one, but I found one I really liked… The Delta T2 (you can pick it up at lowes for $150 or less. I think right now it is $135.00)... I love it. It is a Biesemeyer clone, and ironically, Delta owns Beisemeyer, so probably one of the better clones you can get. I actually found Lumberjocks.com because I was googling for fences and ran across this homemade fence that Hutch had made (another member). What you are going to run into is that you will have to drill all new holes in the rails that come with just about any fence to get it to fit on your tablesaw, unless you get a Beisemeyer, which the same model as the Delta T2, will run you approximately $300 – $400. Or, you could get an aftermarket Craftsman, which would be just about as accurate as what you have now. I have a blog on the fence upgrade… It is here. Just follow each blog entry to see the progress. At first I was a little gun shy and was going to take the fence back, but decided to go ahead and give it a go. All I can say is that it has breathed new life into this table saw, and I couldn’t be any happier. I am glad that I kept the fence. I also have a Craftsman 10” tilt-arbor contractors tablesaw that is circa 1995 (or around there somewhere). I think the model # starts with 113. Both tablesaws have the same hole spacing on the front. My 1952 didn’t have any holes in the back of the table, so I had to drill some. If you are going to do this, make sure that you measure everything over and over for a couple of hours before you drill. One more thing… Most people would just line up the first hole on the rail with the first hole on the table, then drill another hole spaced out to match. The only problem with this is that you won’t be able to use the tape measure on the rail since it will never zero. That’s why I decided to drill all new holes in the rails. I wanted to make sure that I could use the measure to get accurate cuts. If there is anything I can do to help, just let me know.. -- Jamie, Kentucky |
285 days ago |
Mike, when I replaced mine I was also looking for a router table; I opted for the SawTrain by Jointech. I really like the system but, if it weren’t for the need for a router table at the same time, it’s a bit expensive and I probably would have looked elsewhere. It’s the dickens and all to set up but is very accurate. I did have a problem with it not centering a cut on a board; it has a “rabbit and carrot” system that is supposed to help in the process. Uh huh. I tried to get some help from the demo tech at a woodworking show on it and he gave me the bum’s rush like magician would do a kid who was telling the secrets to a trick. Who knows, maybe it’s just ESO (that’s equipment superior to operator). Good luck on your search. Whit -- Even if to be nothing more than a bad example, everything serves a purpose. |
284 days ago |
Hi Mike, I’ll ditto the comments by Jamie. I added the Delta T2 fence to my old Craftsman and it made a huge difference. It wasn’t extremely difficult to install, was a reasonable price and works slick as a whistle. Give it a go and you’ll be pleased with the result. Regards, |
284 days ago |
Thanks guys your advice is greatly appreciated. What I’m kind of leaning towards is the Vega 36” fence. I haven’t found any bad reviews and most of them installed the fence on Craftsman contractor saws. All these reviews claimed that the fence bolted right up to the hole pattern already on the saw. All clams the fence works great, but the cosmetic’s (finish) and the instructions leave a little bit to be desired. If any one has installed a Vega fence on there saw I wood like to hear from you. Amazon has it for 229.99 and if I open an account I get another 30.00 off that. Once again thanks to all and I wish all you LumberJocks a happy Prosperous New Year and may all your woodworking projects turn out great |
284 days ago |
Hi Mike -- Mike www.flickr.com/photos/paturner |
284 days ago |
Thank you guys, I am new to this forum and I am also looking to replace the fence on my 10” craftsman saw thanks for the info as I will be looking into the Delta T2 that you mention. I have a Lowes just down the block from me. When I get it installed I will let you know how it turned out. Thanks again and I am sure I will gain a lot of information from you pros…MIKE -- never enough time in a day so use it well |
284 days ago |
I used a Craftsman contractors saw for years till I was able to up grade. The original equipment fence was a POS needing measuring at both table ends to ensure it was aligned with the blade before locking it down. I already had an Incra router fence so I was aware of how acurate they were so when I saw the TS III fence for the table saw I bought it. It was a great upgrade; easy to install and adust. It made the saw much more acurate and even fun to work with. The biggest draw back (other than price) was it does take up alot of space. but if you buy a bigger saw later it is still better than alot of OE fences. The other inexpensive improvement to the Craftsman TS was the kit offered through Woodcraft which includes 2 cast iron pulleys to replace the OE aluminum ones and the link belt which helped tame the vibration alot. Those along with a good blade and it will be like using a new machine. -- DocK, WV |
284 days ago |
All right you guys convinced me to take a look at the Delta T2 before buying. For all of you who have already installed the T2 how would you rate the documentation that comes with the fence? 5 excellent 1 bad |
283 days ago |
To tell you the truth, it’s a table saw fence.. I have both a hardcopy and pdf version of the documentation, and it goes through installing the fence, then alignment and zeroing. It’s pretty straight forward though. It is specific to Delta table saws, so if you are going to put it on your craftsman, there really isn’t anything in the documentation about modifying the fence. If you want a copy of the manual, I can send it to you through email in PDF form. Just let me know… -- Jamie, Kentucky |
283 days ago |
Mike, -- Jamie, Kentucky |
277 days ago |
Thanks for the advice on the Delt T2 fence. |
277 days ago |
mike, |
276 days ago |
mike |
276 days ago |
I recently purchased a T2 for my Craftsman contractor’s TS (4 yrs. old). Had to drill new holes, but when I had it on, the fence was a good eight inch off of the table. I could live with that, but when I tried to rip a board to test it out, the two nylon adjusting screws, and the two screws for the tape measure site glass were above the table height, so the board could not set level on the table. There is no room in the angle iron on the front to redrill the holes to lower the unit. I didn’t realize I would have this much trouble. I like the fence. Too bad I can’t use it. Any suggestions as to how to fix this? -- Larry, Wisconsin |
276 days ago |
Larry, I also sent you some info in a message that may help. If you do it right, the Delta T2 fence is amazing! If you could, start a blog and post some pictures of what you have done so far. I’ll try to help you get this bad boy set up. -- Jamie, Kentucky |
276 days ago |
I put a Mule fence on a old Grizzly. Every thing fit with no drilling or cutting. Works great. $200 -- WOOD/DON (...one has the right to ones opinion but not the right to ones own facts...) |
276 days ago |
Jeb thanks a lot or the info, the 16 1/2 inches sounds just about right. When you say that the rail allows for inch or so of adjustment I”m I to understant that the mounting holes are Long gated in the horizontal plane? Larry, When I called Delta to get some information on the T2 they told me that the table saw face has to be an 1 1/2 wide to Accommodate the rails of the T2, if there not you will have to redrill the holes like Jamie said. The face on my Craftsman is 1 1/2 wide but from the information Jamie sent me and the measurments I’v taken it looks like I will have to do a lot off drilling to retrofit the T2 to my saw. Because of this I”m back to the Vega. |
275 days ago |
mike, |
273 days ago |
Shoot, get one of those Lowe’s Biesemeyers and slap it on. Did it myself on my CMan 113… contractors saw last summer. Bought 6 of those fences. Piece of cake. Had to drill maybe 4 or 5 holes, easy with the rail clamped to the table and a 1/2” corded drill and a Costco drill bit. And I’m no machinist, not by a long shot. Used a little 3 in 1 as a lube and it worked fine. The fence transformed the saw, just completely made a new saw out of it. Still have 5 of them if anybody wants one, let me know. I figured buying Biesemeyer fences was like buying gold—can’t possibly go down in value :) |
| Sponsor | Forum | Topics |
Woodworking Skill Share
1223 |
1657 |
119 |
334 |
103 |
Woodworking Trade & Swap
233 |
Coffee Lounge
925 |
LumberJocks.com Site Feedback
268 |
