How to fasten down decking on Pirate bed
Forum topic by Russ posted 1068 days ago 880 views 0 times favorited 5 replies Add to Favorites Watch
View Russ's profile
Russ
354 posts in 1250 days
1068 days ago
Topic tags/keywords: question movement
I’ve been working on a pirate bed for my son and I’m having some success. However I’m placing the deck on for the front and I’m worried about handling wood movement. Below is a pic of the bare deck and the 3/4” Poplar planks. How should i mount these? I don’t have access from the underside. So a plan I came up with was to place an over sized hole in the plank then using a screw with out a countersink. Any ideas would be appreciated.
BTW I’ve rounded over the corners on the planks to give a the texture between them.
Bow
Planks
-- Russ
5 replies so far
View Gregn's profile
Gregn
1643 posts in 1156 days
#1 posted 1068 days ago
Have you considered attaching a backer board to the plywood where the decking is to be fastened and using fluted or spiral grooved dowels to attach the decking. I did something similar on a rocking horse and their still holding strong.
87378 posts in 1750 days
#2 posted 1068 days ago
I ‘m not sure from the photo but what about construction adhesive.
View BacktotheWood's profile
BacktotheWood
76 posts in 1194 days
#3 posted 1068 days ago
My dad had refinished several wooden boats including a 1954 Mahogany CrisCraft Inboard. What I remember is some of the baots left the screws showing, either brass or chrome. The CrisCraft had the screws with the heads in holes and plugs over them. I think I would feel better using screws than adhesives, then the question becomes “Do you want to do the extra work of the plugs. I’m sure it will look great.
-- Silence & smile are two powerful tools. Smile is the way to solve many problems & Silence is the way to avoid many problems.
View Russ's profile
Russ
#4 posted 1068 days ago
Thank you all for your advice. I’m leaning towards the screws with plugs. Perhaps combined with the separation sealed with caulk. I welcome any other suggestions though.
-- Russ
View Russ's profile
Russ
#5 posted 1067 days ago
DaveR, Thank you for the additional information.
-- Russ
