blotchy maple end grain
Forum topic by skogie1 posted 09-27-2016 02:44 AM 483 views 0 times favorited 1 reply Add to Favorites Watch
View skogie1's profile
skogie1
117 posts in 1442 days
09-27-2016 02:44 AM
This is an end grain cutting board I made. I’ve never made one before and I’m disappointed to see how blotchy the maple is. I finished the board with Tried and True Original Finish, a polymerized linseed oil and beeswax blend. The dark areas were showing before I put the finish on and of course they really took on life once the oil darkened the board. Is there any way to use maple end grain and not get blotchiness? I looked at some pictures online and it looks pretty common. Any thoughts or suggestions?
1 reply so far
View Tony_S's profile
Tony_S
896 posts in 3162 days
#1 posted 09-27-2016 10:29 AM
I’ve always heard of it referred to as ‘sugar staining’. Most common in summer cut Maple, but can happen in winter cut as well(too long from felling to kiln + warmer temps) but not nearly as common in winter cut.
The easiest way to deal with it, is to not buy it in the first place, but it can be pretty tough to spot on rough sawn maple, especially for a rookie.
Talk to your vendor. They may or may not be able to tell you. Lots will only, or ‘mainly’ buy winter cut for just this reason.
Some will tell you ‘that’s Maple’. That’s the way it is! Bullshat!
-- It is the mark of an educated mind to be able to entertain a thought without accepting it. Aristotle
