Walnut lumber with white blotchy spots, Why?
Forum topic by doubleDD posted 09-27-2016 01:29 AM 1149 views 0 times favorited 29 replies Add to Favorites Watch
View doubleDD's profile
doubleDD
7017 posts in 1915 days
09-27-2016 01:29 AM
I was re-sawning some walnut logs today that I’ve had for a few years and noticed every piece has these white streaks or blotchy look to it. Anyone ever seen this before and know why this happens? I thought this could be spalting in walnut? The logs were 18’’ in diameter cut 4 years ago. It has a moisture content of 12%.
Originally the tree was struck by lightning and the top was blown off. I did cut some smaller logs up for projects over the years from the same tree and never saw any of this. Just some beautiful walnut with the white sapwood on the edges. Any help would be appreciated. Not sure if I like this look yet.
Thanks Dave
29 replies so far
View WDHLT15's profile
WDHLT15
1705 posts in 2348 days
#1 posted 09-27-2016 02:17 AM
White rot from a fungus.
View mike1950's profile
mike1950
363 posts in 1670 days
#2 posted 09-27-2016 02:32 AM
White rot
-- "There are only two ways to live your life. One is as though nothing is a miracle. The other is as if everything is."– Albert Einstein
View DocSavage45's profile
DocSavage45
8430 posts in 2714 days
#3 posted 09-27-2016 02:40 AM
Dave,
Guess you got your answer.
Charles Neil has a method to change the look of the wood with application of different dyes to even out or darken woods.
Maybe you can check with him as he has been posting in the forum recently.
-- Cau Haus Designs, Thomas J. Tieffenbacher
View Jim Jakosh's profile
Jim Jakosh
19957 posts in 2977 days
#4 posted 09-27-2016 02:41 AM
WHITE ROT
View ralbuck's profile
ralbuck
3891 posts in 2138 days
#5 posted 09-27-2016 03:11 AM
When I worked for the lumber yard any wood that we were going to store outside was very carefully stacked to have many air spaces and then rotated fairly often also.
This was to prevent the mold—even in the relatively dry ND climate it did develop.
-- Wood rescue is good for the environment and me! just rjR
View Joe Lyddon's profile
Joe Lyddon
9979 posts in 3924 days
#6 posted 09-27-2016 03:14 AM
WOW! I guess it was White Rot! ... whatever that is…
... I have never seen that happen to Walnut either…
I would listen to Charles Neil for any advice on the subject…
View John's profile
John
1032 posts in 1142 days
#7 posted 09-27-2016 03:47 AM
Thanks for pointing this out Dave, I’m going out to check some roughed out Black Walnut bowls I have.
-- John, Sunshine Coast, BC, Canada.
doubleDD
#8 posted 09-27-2016 03:51 AM
OK, so it looks like I have walnut with white rot. I went back to check it out and it is very stable to say the least. I may have to do some finishing on it to see what it will look like. I wonder if I can somehow stain those blotches so they don’t stand out. Maybe Charles will chime in and give me some ideas. Don’t know if he does PM’s.
Has anyone ever made anything with white rot walnut ?
DocSavage45
#9 posted 09-27-2016 05:12 AM
Dave,
You can pm Charles. here is his website
http://www.cn-woodworking.com/
View Roger's profile
Roger
20895 posts in 2676 days
#10 posted 09-27-2016 11:04 AM
Found this video on the almighty Youtube: https://www.youtube.com/watch?v=47rQYoETWm4
View ellen35's profile
ellen35
2732 posts in 3304 days
#11 posted 09-27-2016 11:16 AM
Bought several rough walnut boards for a project. When I planed them down, they looked just like this. Seems there is a lot of this stuff around. I bought from a very reputable dealer but I don’t think I have any recourse.
Useless….
View rwe2156's profile
rwe2156
2749 posts in 1352 days
#12 posted 09-27-2016 02:18 PM
Wear a respirator when cutting wood like this?
View Underdog's profile
Underdog
1053 posts in 1907 days
#13 posted 09-27-2016 02:31 PM
- rwe2156
Anytime you’re cutting wood with any type of fungus, it’s a good idea to wear a respirator.
-- "woodworker with an asterisk"
View CharlesNeil's profile
CharlesNeil
2172 posts in 3742 days
#14 posted 09-27-2016 02:56 PM
I have seen this in walnut and ‘mahogany, as a matter of fact i am working with some 16/4 mahogany now, that i am cutting into pencil post bed post, and it has this . Before you get too excited, , first try wiping it with some Denatured alcohol and see if the color returns when wet. I have seen this especially in Claro Walnut, I have also seen it return to color after it was exposed to the air, not sure why , but it can do it.
If its truly a mold, then try some peroxide, or uses a mixture of borax, ( good old 20 mule team) of about a cup to a gallon of water, or even a little stronger, you will have to use hot water to get it to dissolve. it will usually kill mold.
Worth a try before trashing the wood
doubleDD
#15 posted 09-27-2016 03:32 PM
Wearing a respirator, good idea, since I usually sneeze a lot when cutting walnut anyway for some reason.
Charles, thanks much for some info on this. I was looking forward to using this on a couple nice project boxes. I will get right on it starting wit a few pieces in the open air and a few with the alcohol and peroxide. I will get back on results. Fingers crossed.
showing 1 through 15 of 29 replies
