How do I interpret the tension spring on a Jet 14" bandsaw
Forum topic by kanihoncho posted 06-22-2010 06:00 PM 5451 views 0 times favorited 6 replies Add to Favorites Watch
View kanihoncho's profile
kanihoncho
56 posts in 3100 days
06-22-2010 06:00 PM
I know there is a lot of discussion on the proper way to tune a blade. My question is on the tensioning spring located on the top back. I have a 3/8” blade on the saw. Do I turn the tension knob so that the bottom of the spring is level with the 3/8” indicator? The manual doesn’t tell how to interpret the blade guage.
Thanks
View davidpettinger's profile
davidpettinger
661 posts in 3227 days
#1 posted 06-22-2010 06:33 PM
The most accurate way is to use a band saw tension gauge. Other wise, crank the handle to the middle of the blade size on the cover, then run a test piece of lumber and check for drift, tighten if necessary. Make sure your rollers or blocks are also properly set.
-- Methods are many,Principles are few.Methods change often,Principles never do.
Rick Dennington
5912 posts in 3221 days
#2 posted 06-22-2010 06:49 PM
Greetings,
+1 for Union Label….. that’s how I’d do it… A lot of times I just push on the blade with my thumb till it
touches the roller bearing, then move it side to side and check the tension that way.. If it’s too lose I tighten
it… if it’s too tight, I loosen it…. you will learn just by feel….... piece of cake…....
View Dave Pearce's profile
Dave Pearce
108 posts in 3699 days
#3 posted 06-22-2010 06:54 PM
Tension the blade up just past the 3/8 mark, fire up the saw, back off on the tension slowly until the blade starts to rattle a bit, then do quarter turns until the saw blade quiets down again. And you’re good.
-- http://www.pearcewoodworking.com
View hairy's profile
hairy
2720 posts in 3559 days
#4 posted 06-22-2010 07:44 PM
I line up the red indicator with the size of the blade I’m setting up. Then just a little tighter. It may not be right, but that has never stopped me before.
-- My reality check bounced...
kanihoncho
#5 posted 06-22-2010 08:04 PM
No red indicator on mine! That would have made it easy!. I just wanted to cover my bases. Many thanks.
View richgreer's profile
richgreer
4541 posts in 3101 days
#6 posted 06-22-2010 10:36 PM
In general, the markings on the sides of the band saw are very inaccurate. You want your tension at about 20000 foot pounds per square inch. I have a tension gauge and I need to tighten significantly tighter than the markings on the side of the saw indicate (e.g. I tighten a 1/4 inch blade as if it were a 1/2 inch blade).
Lots of bandsaw users get pretty good at adjusting tension by feel and/or sound (from plucking the blade).
