Milling/Drying Cherry Logs
Forum topic by SkiTique posted 09-26-2016 05:04 PM 1252 views 0 times favorited 9 replies Add to Favorites Watch
View SkiTique's profile
SkiTique
47 posts in 981 days
09-26-2016 05:04 PM
Hello Everyone,
My brother called me yesterday to let me know he just cut down two cherry trees on his property that are now waiting for me to pick up. He said he has 4 10’ long logs that are about 2’ diameter. Should I seal the ends and let the logs air dry for a year or two, or have them cut and kiln dried now, or I guess cut then air dry? Pros and Cons of each would be appreciated. I have access to an Amish mill where I can have it cut and dried quickly.
9 replies so far
View Woodchuckswife's profile
Woodchuckswife
14 posts in 1425 days
#1 posted 09-26-2016 05:45 PM
I would get the end of the logs sealed with wood sealer or a good covering of paint, then you can get it sawed when ever you want. after sawing make a level spot to pile the boards. pile with 1” x 1 1/2” sticker boards about 3’ apart right in line with each other cover the top with a tarp and weight down real heavy. If air drying it takes a year per 1” thick boards. If kiln dryed restack and cover the same way if stored out side.
good luck
Chuck
View pintodeluxe's profile
pintodeluxe
5738 posts in 2928 days
#2 posted 09-26-2016 05:59 PM
Cherry is especially prone to warping. I would strongly suggest that most of the lumber be milled at 5/4 thickness. 4/4 cherry is often unusable due to warping and twisting if not dried properly.
Seal the ends of the logs and get them milled as soon as possible. Cherry actually dries pretty quickly compared to oak.
View KYSean's profile
KYSean
119 posts in 3711 days
#3 posted 09-26-2016 07:39 PM
General rule of thumb is for air drying: 1 year for each inch of thickness.
-- http://editedwrite.com
View ClammyBallz's profile
ClammyBallz
441 posts in 1251 days
#4 posted 09-26-2016 08:53 PM
Seal the log ends now, then get it cut and air dry it.
These drying charts are very helpful. I purchased fresh cut maple in April and air dried it down to 14% by July. Cutting in spring will give you a substantially faster drying time than cutting in fall. If you cut it now, it should be dry by late spring.
http://www.fpl.fs.fed.us/documnts/fplgtr/fplgtr121.pdf
SkiTique
#5 posted 09-27-2016 12:41 PM
Thanks for the input, I appreciate the help.
View rwe2156's profile
rwe2156
3068 posts in 1595 days
#6 posted 09-27-2016 01:50 PM
If you load on trailer——> to the mill no need to seal log.
Seal boards after cut.
I think pinto brings up a good point. I would have them milled 5/4 also.
SkiTique
#7 posted 09-27-2016 03:15 PM
I agree, 5/4 seems like it would be a good idea, to leave me with a little more material and account for warping.
View soob's profile
soob
269 posts in 1323 days
#8 posted 09-28-2016 05:37 PM
Logs don’t really dry. They’ll basically be wet until they rot, crack apart, or are eaten by bugs. Cherry sapwood will degrade fast, and the heartwood isn’t immune to it either. Get it milled ASAP.
View customsawyer's profile
customsawyer
10 posts in 800 days
#9 posted 10-02-2016 09:22 PM
I would seal the ends ASAP. Cherry is very prone to end checking. If you can get the sawyer to grade saw the logs and leave the pith in a 3×3 or something like that. Any boards sawed that have the pith in them will most likely split on you so don’t try to get wide boards through the middle that contain the pith.
-- In middle Ga. I run a couple of LT70 mills, edgers, Nyle L200 kiln, Pinhero M800 4 sided planer, and lots or rolling stock. www.thecustomsawyer.com
