Some cabinet (FF, rail/stile door, drawer) sizing Q's
Forum topic by AnthonyC posted 06-22-2010 04:14 PM 8648 views 1 time favorited 19 replies Add to Favorites Watch
View AnthonyC's profile
AnthonyC
50 posts in 3143 days
06-22-2010 04:14 PM
Topic tags/keywords: kitchen cabinet rail stile quirk bead sketchup
In the design process of a kitchen remodel.
We have a general layout, style, and color scheme we would like.
Going with 1/4” bead, inset door and drawer front, white/glazed (painted) for the cabinet design.
Rail and stile on the cab doors will be a stepped bead pattern (matching set from Infinity).
A couple of the design decisions we have been agonizing over:
Drawer height. 5”, 6”? Right now I have them at 5 1/2” and I think it looks okay. Tough to tell, though.
Rail / Stile size. Going with a flat panel and the 2” rail/stile look very skinny on the larger doors. Any advice on this? Do you guys make the frame members much larger with flat panels?
Going with 1.5” face frame members, and on the advice on another thread here, made the bottom rail 3/8” taller than the mid rail or top. Seems to balance out the design in Sketchup. My question here is, with a 4” kick space (floor to bottom of frame rail), that puts the bottom shelf 6 5/16” off the floor. Is that too high? Should I make the toe kick less to compensate?
Thanks. I will post some pics of the sketchup plans later.
-- Amateur woodworker, professional mess-maker.
19 replies so far
117417 posts in 3814 days
#1 posted 06-22-2010 04:16 PM
Look forward to photos
View PurpLev's profile
PurpLev
8548 posts in 3885 days
#2 posted 06-22-2010 04:27 PM
As for the toe kick – I don’t think you can reduce it, as it’s designed by functionality more than visual. from what I’m getting you’re planing on having the bottom shelf at the level of the top of the bottom rail? why not leave it on top of the toe kick, and have the rail act as a lip to it? the only downside is that you can’t slide anything out, but will have to pick it up and out – but you’ll gain those extra 2” for storage. may or may not work for you.
anything else goes to visual and preference, make the drawers the size that looks and works best for YOU – that’s what custom work is all about. if you tall items that won’t fit in a 5” drawer – make them 6” , but if those look too tall for you – make them 5” ;). same for the rail/stile components.
make it all work for YOU since this is why you’re building it to begin with isnt it?
AnthonyC
#3 posted 06-22-2010 11:02 PM
let me try some pics here. Front and Iso view of my outside wall. Just the base cabinets. Kick space is 4” in that and the counter will be a full 1.5”. The cutout is for an apron sink.
All thoughts welcome. I’ll add more pics as I get them done.
Front view
Iso View
PurpLev
#4 posted 06-22-2010 11:24 PM
rail stile for panel doors look ok to me not too thin.
however. it looks like these are all ‘stand alone’ cabinets put next to one another? to me all the internal face frame stiles look a bit too wide since they are all doubled up.
AnthonyC
#5 posted 06-22-2010 11:37 PM
Yeah, I’ve been trying to find a way around that. The wide door next to the sink is the dishwasher fake panel (whole faceframe, door, and drawer front will be one piece).
That’s one reason we went with the 4 drawers inbetween, so that it won’t look too odd with door spacing.
View huff's profile
huff
2828 posts in 3522 days
#6 posted 06-23-2010 02:06 AM
Anthony, Did I understand you correctly? You plan on doing a beaded faceframe, but only on the door openings? Are you doing the same for the drawer openings?
As far as the drawer height goes, since you are doing a slab type drawer front, then any height will work fine.
If you were doing a stile,rail and flat panels on the drawer fronts like the doors, then you would need at least 6” in height. I noticed on your drawing that you have a rail between the top and 2nd drawer, but no rails between the others. Did you plan it that way? Usually on faceframe cabinets, there is a rail between each opening.
I usually do a 2 1/4” stile and rail for doors, but it’s more for allowing room for 35mm hinges…..and if you feel the stiles are too wide where the cabinets butt up to one another, you can reduce each of those stiles by 1/4” each. You’d be surprised how much that can change the overall look. Going from 3” where the two stiles butt together to 2 1/2” doesn’t sound like much, but that 1/2” can make a difference. The width of your stiles are going to be more noticable since you are doing a inset door and drawer.
-- John @ http://www.thehuffordfurnituregroup.com
AnthonyC
#7 posted 06-23-2010 02:21 AM
We’re still not sure what we’re going to do with the two small drawer sets. The one on the left is a corner unit and the other one is the dead space between the dishwasher and the end cabinet. We may make the end cabinet larger and forego that altogether.
I plan on beading every opening in the face frame. I threw together those 4 drawer sets this afternoon and hadn’t thought much of that.
And yeah, I have been noticing how much of a difference 1/4” makes. I widened the bottom rail by 1/2” and all the dimensions in the door by 1/4” to get to what you see up there. It didn’t look like much when I did it, but the effect was noticable. I also played around with 3/8” vs 1/4” beading and that made a huge difference.
The dishwasher is driving most of this. I would halve the stiles so that they all looked uniform when butted together. But I am worried that this would leave too little support on the edges of the D/W frame. Hmm, more to think about.
Thanks for all the help, guys.
View CampD's profile
CampD
1741 posts in 3723 days
#8 posted 06-23-2010 02:26 AM
For full inset doors I do 1 1/2” FF sides and bottom and 2” for top and 2” rail/styles. I’ve found it looks the best. I’d do 2 drawers instead of 3 on the lower with a rail in between. With inset doors I almost never put a style between the doors (ever try to fit under or work on the sink?). I put the dado at 5 1/2” and with a 1 1/2” FF leaves 4” kick space.
Click for details
-- Doug...
View Howie's profile
Howie
2656 posts in 3160 days
#9 posted 06-23-2010 04:25 AM
I know you stated you have a design,but have you considered overlap doors? Just a thought.
CampD, if you do overlaps what is your top rail size?
-- Life is good.
AnthonyC
#10 posted 06-23-2010 04:54 AM
We like inset doors and since I’m building them myself, we think it will add a touch of distinction that we couldn’t get with buying them. The house is a colonial revival and we’re going with a French country / colonial hybrid style. So we are trying to go with simple lines. Plus our current (ugly) cabinets are overlay style and we are little biased against them :)
An idea I’m going to try in sketchup tomorrow is to make two or three fake drawers (no frame rails inbetween) on the D/W. Then I can halve the vertical frames between the cabinets, which will also make those small drawers wider and even out the spacing. Still need ideas for the left corner cab.
It’s nice to have Sketchup for stuff like this. I would hate to trial and error this with real wood.
CampD
#11 posted 06-23-2010 02:10 PM
Howie,
When I do overlap doors, FF is 2” & rail/style 2 1/2”. The extra 1/2” overlaps sp the overall effect is the same.
Top rail of face frame is still 2”. I do a bigger top rail to give extra room for any type of countertop, you never know down the road what the owner will change (yrs of experience doing kitchen remodels) I’ve seen heavy counters put in and the rail will almost disaiper.
-- Doug...
Howie
#12 posted 06-23-2010 03:04 PM
Anthony: you are correct in your choice for the french/colonial styling. Keep us updated, it sure looks like and interesting project.
CampD: thanks
-- Life is good.
AnthonyC
#13 posted 06-23-2010 11:28 PM
Okay, updated design.
Made it into two cabinets with the fake dishwasher panel.
I’m thinking of making the end cabinet a single drawer for a recycling or trash (look like a narrow door instead of three drawers). I may also make the dishwasher look like it has two fake doors instead of three drawers.
But I do like the extra space and spacing of the “condensed” version.
New elevation
View rhett's profile
rhett
742 posts in 3904 days
#14 posted 06-24-2010 02:18 AM
I would bring the 4 drawer stacks in to both sides of the farm sink. This would give you more symmetry in the run of cabinetry. There is no set rule stating that the DW has to be directly next to the sink. Pumps on present day DW’s are very stout and can push allot of water.
I did a kitchen a few years ago where we put the DW on an entirely different wall.
-- Doubt kills more dreams than failure.
AnthonyC
#15 posted 06-29-2010 08:17 PM
Okay, some design rework. The wife and I are liking this one a lot better.
new design front
new design iso
We decided to do a blind corner cabinet (not shown) on the east elevation, so the drawers by the sink would fit in better. We decided not to do a built-in hutch style end cabinet, so no need for the asymmetry on the right cabinet. I could just make a nice centered double cabinet.
Please let me know if you see any traps or gotchas. I’ll try to do the east wall tonight and show the whole line of cabs.
Thanks again for all the input!
