Which table saw insert is better for using a dado blade
Forum topic by BillHall posted 09-26-2016 01:41 PM 404 views 0 times favorited 4 replies Add to Favorites Watch
View BillHall's profile
BillHall
6 posts in 923 days
09-26-2016 01:41 PM
Topic tags/keywords: tablesaw joining
Hi guys,
I want to do some dados on my table saw but was wondering about the saw insert. Is it better (safer) to use the dado insert or a zero clearance insert? Thanks for your feedback
-- Bill, Leland, North Carolina
View mike02130's profile
mike02130
167 posts in 666 days
#1 posted 09-26-2016 02:32 PM
Trace the insert on a piece of plywood or poplar and use that. Lower the blade and slowly raise it up. Zero clearance. Just make sure you hold the insert down when you’re raising the blade.
-- Google first, search forums second, ask questions later.
View brtech's profile
brtech
1029 posts in 2916 days
#2 posted 09-26-2016 02:50 PM
The smaller the gap between the blade and the insert, the safer, but the real reason for a zero clearance insert is to support the fibers of the wood to get less tear-out.
View pintodeluxe's profile
pintodeluxe
5653 posts in 2807 days
#3 posted 09-26-2016 03:03 PM
Make or buy a ZCI for the specific dado width you plan to make. While you’re at it, make one for each common size including a 3/4” stack. That is the size I use most frequently.
I prefer MDF for making ZCI’s, or better yet MDF covered with Formica.
BillHall
6 posts in 923 days
#4 posted 09-26-2016 05:24 PM
Great advice, guys. Thanks very much.
