Poor Results from Amana Tool 100T blade in DWS780
Forum topic by LBH posted 09-25-2016 05:23 PM 1368 views 0 times favorited 21 replies Add to Favorites Watch
View LBH's profile
LBH
109 posts in 1158 days
09-25-2016 05:23 PM
I am going to help my friend install some WindsorOne base and case for 14 doors an hall, 3 bedrooms….
He’s had a DeWalt DWS780 miter saw for some time but it gets little use. I borrowed it to cut some plywood that I need for small concrete forms. I’m using scrap 3/4” pre-finished maple ply. Anyway… The cuts were terribly frayed. I told Tim a new blade was needed before the B&C job. We decided on an Amana Tool 100 tooth 12” blade. It was priced in a sweet spot between Freud and Forrest and I have had great luck with Amana router bits.
I installed the blade and made two cuts. One on the plywood and on on 5/4 hickory.
I could not believe my eyes! The top edges were terrible. Better than the old Dewalt blade, but totally unacceptable for a $90 finish blade. Strangely, the bottom edge is pretty good. (No zero clearance plate)
Any suggestions will be greatly appreciated.
Luke
Here are the photos.
-- Disclaimer: Author does not warrant the accuracy of the comments in this post including spell'n and frammer. I'm just another Dufus on a forum.
21 replies so far
View Aj2's profile
Aj2
1361 posts in 1766 days
#1 posted 09-25-2016 07:08 PM
I have that blade but only use it for trim work.Crown molding Etc.
For solid wood cross cut I have a Amana 72 tooth.
For dran near perfect miters I use Forrest Chop master.
The one difference is that I have Scms Bosch glide.
So I enter the cut at the corner edge of my stock instead of the face.I don’t know for sure if it makes a difference but it might help.
Aj
-- Aj
View LBH's profile
LBH
#2 posted 09-25-2016 07:42 PM
Hi AJ
Agree. Ordinarily I wouldn’t use it for hardwood. I just grabbed it for a test. That said it should do a great job with the ply. My Festool TS55REQ cuts it amazingly.
I don’t think it’s the blade because the results look a lot like the FeWalt blade.
Cavitation maybe ???
View LBH's profile
LBH
#3 posted 09-25-2016 07:45 PM
Just thought about your post. Yes when I cut the case and base the stock will be against the fence. (Not flat)
View Aj2's profile
Aj2
#4 posted 09-25-2016 08:07 PM
Hi AJ
Agree. Ordinarily I wouldn t use it for hardwood. I just grabbed it for a test. That said it should do a great job with the ply. My Festool TS55REQ cuts it amazingly.
I don t think it s the blade because the results look a lot like the FeWalt blade.
Ive wondered what it is about 12inch blade and they way they cut on miter saws.Theres must be a lot more going on then we realize.It just hurts my head trying to figure it out.Thats probably why i have three different blades now.
Thats a great saw Festool makes some nice tools.
Aj
- LBH
-- Aj
View RogR's profile
RogR
110 posts in 833 days
#5 posted 09-27-2016 06:10 AM
I can’t recall even an inexpensive blade that did not cut well when brand new. I would try some different wood.
Does the back side have a cleaner cut than the front? Often the trick with plywood with thin veneers is simply to cut it backwards – i.e. with the good face down. Either that or score with a sharp knife first and then cut to the score.
View joey502's profile
joey502
525 posts in 1486 days
#6 posted 09-27-2016 10:26 AM
I could be wrong but the teeth look like they are designed for use on a sliding saw (it looks like a negative hook tooth). The tooth angle on blades designed for use on a sliding saw do not tend to plunge cut well.
joey502
#7 posted 09-27-2016 10:38 AM
I just googled that model and it is a negative hook. That blade on a slider or a different blade with a more agressive (positive angle) tooth would perform a better on a chop style saw.
View LBH's profile
LBH
#8 posted 09-27-2016 03:20 PM
- RogR
Yes the backside appears cleaner. I am getting better results (on plywood) by not plunging all the way down before gliding.
The other thing is this is the Chinese 3/4” pre-finished birch. I always by domestic. I have the plywood deliver, when it arrived I saw it was imported. I looked at the invoice and the counter man indeed charged me for import. I thought I’d give it a try. It’s de-laminating is some areas. That might explain the poor results.
View LBH's profile
LBH
#9 posted 09-27-2016 03:23 PM
- joey502
Joey,
Thank you very much for researching the blade. A) I have no idea what a negative hook does B) I’ve never heard of it.
So not only do I find out what may be going on, but I learn something too.
I truly appreciate the time you took. A true Lumberjock.
Luke
View DirtyMike's profile
DirtyMike
637 posts in 870 days
#10 posted 09-27-2016 03:38 PM
A negative hook blade is meant to be dragged through the wood as opposed to chopped down or pushed. They are a must for radial arm saws and sliding miters. I wouldn’t think that it would give you such lackluster results though.
joey502
#11 posted 09-27-2016 04:45 PM
If you google “sliding compound saw blade” the second or third site is a rockler article called saw blade 101. It has a lot of info regarding blade types and tooth configurations.
I have a 12” sliding saw with a negative hook angle blade on it. If i pull the saw out, drop it down and the push the blade into the piece it cuts like butter. If the blade is pushed back and plunged into the work piece the cutting action is terrible.
joey502
#12 posted 09-27-2016 04:47 PM
joey502
#13 posted 09-27-2016 04:52 PM
My apologies. I did not realize that model dewalt was a slider, that blade is fine for that saw.
DirtyMike
#14 posted 09-27-2016 05:20 PM
Joey, are negative hooked blades not to be pulled through the cut rather than pushed?
View LBH's profile
LBH
#15 posted 09-27-2016 05:54 PM
I’m going to be installing WindsorOne, S4SSE, base and case. Do I cut it flat or upright against the fence.
I can check a Gary Katz video but I thought I’d ask since this thread is going and the blade will be a factor.
Thanks
Luke
