How thin is too thin
Forum topic by tealetm posted 09-25-2016 01:39 PM 781 views 0 times favorited 9 replies Add to Favorites Watch
View tealetm's profile
tealetm
102 posts in 1029 days
09-25-2016 01:39 PM
How thin is too thin for an end grain cutting board? I am finishing a board that ended up being thinner than planned because I did a poor job clamping and had a bow in the bird I had to take out.
Right now the board is about 7/8” thick. I’m going to put feet on it and am worried about it snapping in the middle.
It was going to be a gift but I don’t want to give it away if it’s going to break while being used.
It’s an 10”x14” board, and titebond II hold the maple, cherry and walnut together.
9 replies so far
View pmayer's profile
pmayer
1032 posts in 3236 days
#1 posted 09-25-2016 03:05 PM
Nice looking board. I don’t think it will snap, but they seem to be more prone to cupping due to uneven exposure to moisture when they are under 1”. I normally make them between 1.25” and 1.75”. If you are concerned about snapping just don’t put feet on it. With no feet they can cut on one side and serve on the other.
View Joe Weaver's profile
Joe Weaver
518 posts in 3857 days
#2 posted 09-25-2016 03:27 PM
very nice
-- Joe, Ga
View bbasiaga's profile
bbasiaga
1240 posts in 2166 days
#3 posted 09-25-2016 04:13 PM
Or you could put additional feet in the middle so the unsupported span is much less.
Brian
View Matt Hegedus's profile
Matt Hegedus
146 posts in 964 days
#4 posted 09-25-2016 04:59 PM
You could put feet 1” on center the whole way around. About 140 of them… :-D
-- From Pittsburgh, PA
View ducky911's profile
ducky911
237 posts in 2960 days
#5 posted 09-25-2016 07:34 PM
Hi,
Are the long thin maple strips end grain? Just wondering as I have made a couple boards like that and did not end grain the thin strips. Always thought that I may have broken a glue rule.(long grain cross grain)
View Aj2's profile
Aj2
1784 posts in 1969 days
#6 posted 09-25-2016 08:13 PM
Ducky911 has a good point. If the maple is long grain mixed with end grain is going to fail soon.
Please tell us they are end grain. Its a nice looking board
Aj
-- Aj
tealetm
#7 posted 09-25-2016 11:00 PM
Everything is end grain- including the long strips. Those were quite the challenge to cut on a tablesaw…
I was thinking of putting more feet on it. I’m a bit hesitant to have no feet because water is more likely to unevenly soak in if the board is set in a puddle.
Thanks for the compliments- it’s my favorite board yet.
View Dark_Lightning's profile
Dark_Lightning
3284 posts in 3280 days
#8 posted 09-25-2016 11:54 PM
Nice board! I think more feet is the answer. A question- is it going to be used on a granite or cement counter? if you use a lot of feet, the surface will have to be near dead flat to take the stress out of bending, like say on a tile counter. They can be pretty uneven, and you won’t have all the feet on the surface if it is uneven. People may not be applying that much force. I’m used to designing for challenging environments, thus the question.
-- Random Orbital Nailer
View bigJohninvegas's profile
bigJohninvegas
500 posts in 1633 days
#9 posted 09-26-2016 04:54 AM
I make most of my boards around 1-1/8th inch thick. And have never put feet on one. I don’t think you will have any problems at 7/8”. I only make boards thicker on request. And feel the thick boards are hard to handle. I have at least 50 boards out there. And no one has ever told me of a failure. Several customers have been afraid to ruin such a nice bowrd by cutting on it. Without feet, I tell them all to cut on one side and display the other.
-- John
