How do I do this???
Forum topic by stuk4x4 posted 06-21-2010 07:11 PM 1155 views 0 times favorited 3 replies Add to Favorites Watch
View stuk4x4's profile
stuk4x4
115 posts in 3303 days
06-21-2010 07:11 PM
Topic tags/keywords: question
I have built one corner shelf before and it was very hard for me to do, it was cut a little then measure again and then cut some more then get the board stretcher out and try it again!!! The end result turned out ok but this time I am looking to do it a little better and not have so many problems. I would like my end result to be a shelf that slides into to pieces of lumber with Dado’s that are mounted on both walls. Also the front of the shelf would be curved.
Any help would be greatly appreciated.
Thanks
Walt
-- All the tools in the world wont make you a good mechanic or craftsman... however it helps!
3 replies so far
117417 posts in 3813 days
#1 posted 06-21-2010 07:14 PM
take a look at this
http://www.woodworkingcorner.com/cornershelf.php
View Michael Murphy's profile
Michael Murphy
453 posts in 3241 days
#2 posted 06-21-2010 09:03 PM
The construction of it doesn’t sound too complicated, it sounds as though you are having trouble making it fit the walls in the corner. Sheet rocked and mudded walls typically are not real straight or square in a corner because of all the extra mud the sheetrockers use in corners. I would put the cleats on the wall, make sure the dadoes in the shelf edges are extra deep, and make a cardboard or masonite pattern that fits the wall at the level of the cleats, then transfer that to the shelf to cut it to fit.
-- Michael Murphy, Woodland, CA.
View BCinPhx's profile
BCinPhx
23 posts in 3164 days
#3 posted 06-21-2010 09:30 PM
Did the same project once…Michael Murphy above hit it at least partially on the head. I had to take a router with a round over bit AFTER I built the corner shelf. Due to the corner itself not being flat or at 90 degrees. If you take the router to the rear spine (assiming you can remove it OR when making your new one) just might help the fit. There are other factors involved and one tip might be to take a rafter square or the equivalent and measure the corner for angle accuracy and flatness. If you have to build it a little ‘sloppy’, remember nice trim hides a small error.
Just my 2 cents.
-- CPT Bill - No matter how many times I cut it...it still comes up short !
