Mastercraft 12-in. Lathe with Chisel Set - $159.99
Forum topic by Zuki posted 327 days ago 198 views 0 times favorited 1 reply Add to Favorites
View Zuki's profile (online now)
Zuki
925 posts in 605 days
327 days ago
Topic tags/keywords: mastercraft lathe
Mastercraft 12-in. Lathe with Chisel Set – $159.99
http://www.canadiantire.ca/browse/product_detail.jsp?FOLDER%3C%3Efolder_id=1408474396672966&bmUID=1199139605701&PRODUCT%3C%3Eprd_id=845524443294672&assortment=primary&fromSearch=true
If you click on the link and need a postal code – use A1C 5M2
12” mini wood lathe with chisel set
120 V, 2.3 A variable speed motor (750 3200 rpm)
Adjustable tailstock holds work pieces up to 12” long
6” faceplate on the ¾ – 16” thread drive spindle for inboard turning
Cast-iron headstock and tailstock
Number one Morse taper spur centre and taper ball-bearing cup centre
Includes: Adjustable 4½ and 7” tool rests, 2 and 6” inboard faceplates, Push-out rod and Wrench
Does this look any good ?? The price certainly does.
View GaryK's profile
GaryK
8541 posts in 517 days
327 days ago
Looks pretty good for the price. I wouldn’t expect it to last 20 years though.
For small projects it should work pretty good.
After using it a while you might decide to go for something better/bigger.
Then you will know what to look for and what you need in a better one.
All this without spending a lot of cash.
Bookmark And Share This Page
