problem with delta planer
Forum topic by skidiot posted 09-23-2016 03:18 AM 874 views 0 times favorited 4 replies Add to Favorites Watch
View skidiot's profile
skidiot
76 posts in 3696 days
09-23-2016 03:18 AM
Topic tags/keywords: planer
Hi,
I just bought a used Delta 22-580 planer. It dont look as though it has been badly abused. The price was great. But there is a problem. It makes a wavy scalloped cut, not flat. Nothing visible, but you can easily feel it. The blades are new. It feeds just fine. I am thinking either a bent head or bad bearings. Any other ideas. I was planning on putting a Shelix head on it at some point, just not right away. Thanks
-- skidiot northern illinois
skidiot
#1 posted 09-23-2016 03:31 AM
Hi,
I forgot to mention that the head lock seems to be working fine. I am getting zero end snipe.
View jumbojack's profile
jumbojack
1678 posts in 2675 days
#2 posted 09-23-2016 06:03 AM
Did you replace the blades or were they replaced by previous owner. If the latter I would reinstall. Check that the blades are identical in width.
View distrbd's profile
distrbd
2252 posts in 2497 days
#3 posted 09-23-2016 01:52 PM
+1 What jumbo said.
-- Ken from Ontario, Canada
View splintergroup's profile
splintergroup
2143 posts in 1273 days
#4 posted 09-23-2016 01:58 PM
I find that if the blade retainer isn’t properly tightened or is warped, wood can get jammed underneath which will distort the blade.
