Questions For Kitchen Cabinet Builders
« back to Sweating for Bucks Through Woodworking forum
Forum topic by David Freed posted 09-22-2016 08:16 AM 1188 views 0 times favorited 6 replies Add to Favorites Watch
View David Freed's profile
David Freed
113 posts in 3869 days
09-22-2016 08:16 AM
Are your face frames 3/4” or 13/16”?
What thickness plywood do you use in the sides, floor, and back of your boxes?
What do you use for a nail rail?
Any reasons for why you use any of the above?
-- David, Southern Indiana
View Loren's profile
10477 posts in 3849 days
#1 posted 09-22-2016 10:37 AM
1. either one. Depends on the rough stock quality.
2. 3/4
3. yes.
weight.
View cabmaker's profile
cabmaker
1740 posts in 3010 days
#2 posted 09-22-2016 10:39 AM
There are exceptions to every rule but basically
3/4…...on the FF…....so as to get a more uniform thickness than the SLR 13 /16 offers
ply…..3/4,,,,,,backs on uppers only (1/4 type}
nailing rail…..2 1/4
View rwe2156's profile
rwe2156
3171 posts in 1682 days
#3 posted 09-22-2016 12:39 PM
I generally go frameless, but if there are FF’s, I don’t care anywhere from 11/16 -3/4 if starting with surfaced stock or thicker if starting with rough stock.
I use 3/4 for base and 5/8 for uppers. I generally use full thickness material for the backs. It costs a bit more, but offset by labor – the assembly is only 1 step – no grooves, etc. If I do go with a rail, its 4” wide.
I generally only use double sided melamine, not plywood. (Personal choice, but there are advantages to a light colored laminate surface on the interior of cabs. Also, premium plywood in a cab box drives cost up almost double especially if using prefinished).
If you’re dead set on plywwod in a kitchen, I definitely would laminate the interior.
View Drew's profile
Drew
350 posts in 3301 days
#4 posted 09-22-2016 08:48 PM
I use 5/8” (15mm) russian birch plywood for my boxes. I used to use 3/4” baltic birch but switched a few years ago. Better quality, lighter weight, thicker veneer and the price is about the same.
I make my face frames 23/32” (18mm) thick. This is where euro style face frame hinges are at their happiest.
-- TruCraftFurniture.com
View MT_Stringer's profile
MT_Stringer
3183 posts in 3433 days
#5 posted 09-22-2016 09:41 PM
The door hinges I use are made for 3/4 inch face frames.
https://www.amazon.com/Blum-Compact-Soft-close-Blumotion-Hinge-pack/dp/B00WH1XSCC/ref=sr_1_2?ie=UTF8&qid=1474580138&sr=8-2&keywords=blum+soft+close+hinge
David Freed
#6 posted 09-24-2016 12:39 AM
Thanks for all the replies. All the shops in my area make their cabinets the same way. I wanted to see some other methods before I start building.
