Craigslist Unisaw
Forum topic by Joel J posted 09-22-2016 01:27 AM 1230 views 0 times favorited 20 replies Add to Favorites Watch
View Joel J's profile
Joel J
48 posts in 2086 days
09-22-2016 01:27 AM
I went to look at a Unisaw today and the seller said he was the second owner and thought it was about 20 years old. The saw had a Made in the USA sticker on the cabinet. The seller said it wasn’t running. He indicated about 3 weeks ago, he turned it on and a piece of wood was stuck in the blade below the table and the motor made a noise and then just wouldn’t run. My question: Has anyone had this happen and what is the cause of the motor not starting now? Thanks for your help and answers!
-- Joel, Denver, CO
20 replies so far
View MrUnix's profile
MrUnix
6943 posts in 2345 days
#1 posted 09-22-2016 01:30 AM
First guess would be that he tripped the starter overload and needs to manually reset it.
PS: If you are thinking about buying it – use it as a negotiation point! Knock a few hundred off because the ‘motor is toast’ and will need ‘replacing’ :)
View muleskinner's profile
muleskinner
897 posts in 2583 days
#2 posted 09-22-2016 01:32 AM
delete
-- Visualize whirled peas
Joel J
#3 posted 09-22-2016 01:47 AM
Brad,
Where is the starter overload located? On the motor? Thanks
-- Joel, Denver, CO
View DirtyMike's profile
DirtyMike
637 posts in 1048 days
#4 posted 09-22-2016 01:51 AM
sounds like you have an opportunity to get it for cheap. how much was he asking?
MrUnix
#5 posted 09-22-2016 02:19 AM
Brad,
- Joel J
Depends… older ones had a NEMA starter in a box hanging off the back of the machine, later labeled as the LVC (low voltage control – same thing). Sometime during the Black and Decker years IIRC, they started using an IEC type control mounted on the front of the saw. I highly doubt there will be an overload on the motor itself.
Joel J
#6 posted 09-22-2016 05:19 PM
Brad,
Thanks for your help on this. When i get it home this weekend I’ll explore it a bit more.
Mike,
Stole the saw….$ 300.00 in very good condition
-- Joel, Denver, CO
DirtyMike
#7 posted 09-22-2016 05:47 PM
sweet bro, i stole one last week for less that that. i am still grinning.
View teejk02's profile
teejk02
485 posts in 1272 days
#8 posted 09-22-2016 09:24 PM
Brad,
Thanks for your help on this. When i get it home this weekend I ll explore it a bit more.
Mike,
- Joel J
Have to wonder why the motor “tripped” in the first place but at that price you have plenty of $$$ room to fix it and still have a great machine at less than you could replace it for. Not familiar with the Unisaw but my Delta contractor saw built around the same time does have a red “reset” button on the motor itself.
teejk02
#9 posted 09-22-2016 09:27 PM
- DirtyMike
No such thing as a bargain on used machinery around here…large Amish population that loves and uses old stuff and they pay cash.
MrUnix
#10 posted 09-22-2016 09:43 PM
Have to wonder why the motor “tripped” in the first place [...]
- teejk02
Go back and read the original post so you can stop wondering :)
View splatman's profile
splatman
586 posts in 1545 days
#11 posted 09-23-2016 05:32 AM
If the motor hums and nothing else, remove the belts, turn it on, and give the shaft a twist. If it spins right up, the starter is the problem.
View knotscott's profile
knotscott
8129 posts in 3522 days
#12 posted 09-23-2016 09:40 AM
Check the capacitors if the reset doesn’t help.
View mike02130's profile
mike02130
170 posts in 819 days
#13 posted 09-23-2016 12:23 PM
And you’re proud you “stole” the saw? Getting a deal is one thing but taking advantage of a dope is, well I won’t say it here. In the old days they called them carpet baggers.
-- Google first, search forums second, ask questions later.
View dhazelton's profile
dhazelton
2789 posts in 2443 days
#14 posted 09-23-2016 12:28 PM
”....and they pay cash” – doesn’t everybody when it comes to CL? If someone showed up at my house to buy something with a checkbook I’d send ‘em off to an ATM.
Joel J
#15 posted 09-23-2016 03:14 PM
And you re proud you “stole” the saw? Getting a deal is one thing but taking advantage of a dope is, well I won t say it here. In the old days they called them carpet baggers.
- mike02130
Just paid the guy what he was asking for it! Didn’t even ask him to knock of 25 bucks! So technically I didn’t steal it, just found a really good deal at a “Moving Sale”! Haha.
-- Joel, Denver, CO
