Hardwood vs. Softwood
Forum topic by JimmyJack posted 06-18-2010 08:58 PM 1977 views 0 times favorited 15 replies Add to Favorites Watch
View JimmyJack's profile
JimmyJack
28 posts in 2932 days
06-18-2010 08:58 PM
Topic tags/keywords: question tip
I have seen in a couple of comments made on projects where people are talking about using hardwood or softwood. As a beginner, I am not sure how to tell the difference between the two. Can someone please post an explaination of how to distinguish the two?
-- Jim -- Louisville, KY
15 replies so far
View Michael Murphy's profile
Michael Murphy
453 posts in 3028 days
#1 posted 06-18-2010 09:03 PM
How about this?
-- Michael Murphy, Woodland, CA.
JimmyJack
#2 posted 06-18-2010 09:08 PM
That should work…
View Nomad62's profile
Nomad62
726 posts in 2981 days
#3 posted 06-18-2010 09:10 PM
That about sums thing up alright, but I’d disagree with #8.
JimmyJack
#4 posted 06-18-2010 09:20 PM
Anybody else want to argue over Poplar being hard or soft? lol
View hObOmOnk's profile
hObOmOnk
1381 posts in 4151 days
#5 posted 06-18-2010 09:33 PM
The general meaning of these types of wood are:
Hardwoods are deciduous, have broad leaves that seasonally fall off.
Softwoods are coniferous, have needle leaves and are generally evergreens.
The designations have nothing to do with the relative hardness or softness of the woods.
Example, Southern Yellow Pine is a softwood but it is usually much harder than poplar, a hardwood.
-- 温故知新
View CharlesNeil's profile
CharlesNeil
2410 posts in 3894 days
#6 posted 06-18-2010 09:56 PM
Hobomonk got it right , its a classification not a description
JimmyJack
#7 posted 06-18-2010 10:11 PM
That helps too…thanks guys.
hObOmOnk
#8 posted 06-19-2010 12:34 AM
A few examples:
Hardwoods include walnut, cherry, poplar, oak, maple.
Softwoods include spruce, fir, pine, cedar, redwood.
-- 温故知新
117115 posts in 3600 days
#9 posted 06-19-2010 12:46 AM
If I remember right balsa is categorized as a hardwood. showing hardwoods don’t have to be hard. Confusing isn’t it.
JimmyJack
#10 posted 06-19-2010 06:16 AM
wow Jim…you can say that again.
View WoodNuts's profile
WoodNuts
74 posts in 2972 days
#11 posted 06-19-2010 06:34 AM
JJ, Check out this info…
Janka hardness test
http://en.wikipedia.org/wiki/Janka_hardness_test
-- ...there's a fix fer dat...
View Ken90712's profile
Ken90712
17563 posts in 3212 days
#12 posted 06-19-2010 10:24 AM
Good info for all.
View JJohnston's profile
JJohnston
1622 posts in 3315 days
#13 posted 06-19-2010 04:39 PM
The chart in the link says hardwoods are found everywhere, while softwoods are found in the northern hemisphere. Are there no softwoods in the southern hemisphere?
-- "A man may conduct himself well in both adversity and good fortune, but if you want to test his character, give him power." - Abraham Lincoln
View Sawkerf's profile
Sawkerf
1730 posts in 3092 days
#14 posted 06-26-2011 10:38 PM
The real kicker is that balsa is technically a hardwood.
View Loren's profile
10476 posts in 3671 days
#15 posted 06-26-2011 10:59 PM
It is more challenging in some ways to do fine, detailed work
in softwoods. They tend to bruise easily, but some can be
hand planed to an exquisite surface.
A lot of beginners make crude things from soft pine: bunk beds
and coat-racks and things. Everything has to be a little beafier
in softwoods because they aren’t as strong as hardwoods in
narrow sections… so a coat hook made from pine has to be
pretty clunky compared to one made from oak, for example.
If you know what you’re doing and work carefully some really
nice work can be done in softwoods. You have to be very careful
to not drop your boards because they will dent. Softwoods
are favored for a lot of instrument building because in some
cuts they have a higher stiffness-to-weight ratio than hardwoods.
