Mobile bases
Forum topic by swayze posted 06-18-2010 01:23 AM 1179 views 0 times favorited 8 replies Add to Favorites Watch
View swayze's profile
97 posts in 3021 days
06-18-2010 01:23 AM
Topic tags/keywords: mobile bases
I just ordered Grizzly 0513 bandsaw and I will need to put a mobile base under it. I seen there are 2 HTC reviews but nothing else. Any others out there? Where’s the cheapest place to get them from? Thanks
8 replies so far
117030 posts in 3510 days
#1 posted 06-18-2010 01:26 AM
HF sells some they work but not as well as the metal ones. My band saw was way to short so I had to make a box to put it on and then put the box on a mobile base.
-- wood crafting & classes
View Rick's profile
9214 posts in 2966 days
#2 posted 06-18-2010 02:42 AM
This is one Post on here about Mobile Bases.
There are 3 others I believe that you can follow from there.
I bought one from Lowes for $80. Suits me just fine. Some of the Reviews show less expensive but basically the same type of base.
Hope this is of some help.
-- Carrying Anger is like Swallowing Poison and waiting for the Other Person to Die!
View SnowyRiver's profile
51457 posts in 3413 days
#3 posted 06-18-2010 02:51 AM
I have some Jet moble bases and they seem to work well.
-- Wayne - Plymouth MN
View SouthpawCA's profile
270 posts in 3166 days
#4 posted 06-18-2010 02:52 AM
I have a Shop Fox that worked great till the wheels started falling apart. It is the super duper heavy duty one that was suppose to hold something like 1300 lbs. It holds my table saw which doesn’t even come close to that amount. It’s still usable and eventually I’m going to replace the wheels. BTW – I also had the same problems with Rockler wheels. First the rubber started peeling off one wheel then eventually the others. Would I buy it again – probably, however, I’d have another set of wheels just in case.
-- Don
View Howie's profile
2656 posts in 2856 days
#5 posted 06-19-2010 02:47 PM
Frankly, I have my grizzley 555 extreme on a movers dolly I bought at HF. Wrks just fine however I only pull it out and move it back about 3-4 ft. I had it on a WC metal dolly and really didn’t think much of it. In fact it’s for sale. That metal one didn’t work very good for my ridgid jointer either.
-- Life is good.
#6 posted 06-20-2010 01:09 AM
Howie I thought about your idea, either build it or buy it, just thought I would see what was working for everyone else. I also need to see how high the table is and see if raising it will be a problem.
View dbhost's profile
5687 posts in 3165 days
#7 posted 06-20-2010 01:37 AM
I have my HF 32208 14” band saw on the HF universal mobile base. The lumber size is funny (1.25” sq) so you need to rip 2×4s VERY carefully to make it work… But once set up, they work really nice. Weight rating is FAR above what your band saw weighs…
Did you get the white one or the older style green one?
-- My workshop blog can be found at, YouTube Channel
#8 posted 06-20-2010 09:11 PM
dbhost I bought the white one. It was a heck of a deal. Probably more saw then I require but for the difference between it and the 0555 I figured what the heck. At least I have room to grow as someone said.
