Dust Collector for NEW (today) Dewalt 788 - Will THIS work?
Forum topic by Nikki posted 09-18-2016 03:21 AM 1734 views 0 times favorited 25 replies Add to Favorites Watch
View Nikki's profile
Nikki
80 posts in 770 days
09-18-2016 03:21 AM
TODAY I finally got this Scrollsaw with the stand. It’s a nice little saw but I’d like to use this indoors. I do not want tiny dust particles floating around my house. Would something like this be sufficient if I took off the blow tube and rigged up something underneath the table? I’ve seen DIY modifications that can easily be made and apparently this one isn’t too loud.
http://www.busybeetools.com/products/dust-collector-1hp-570cfm-1-mic-bag-csa-ct053.html
Then I’m going to get one of these Wen portable dust collectors to hang from the ceiling.
http://m.homedepot.com/p/WEN-3-Speed-Remote-Controlled-Air-Filtration-System-3410/205465910
Any suggestions or comments regarding this topic?
25 replies so far
View TheFridge's profile
TheFridge
9464 posts in 1484 days
#1 posted 09-18-2016 04:11 AM
Upgrade the filter bag and I think your set.
View Redoak49's profile
Redoak49
3244 posts in 1987 days
#2 posted 09-18-2016 11:21 AM
I have a scroll saw and have a different solution. Dust collection is best done as possible to the source.
I am using a HEPA rated vac which is rated for continuous duty. It is connected to the top and bottom of the scroll saw with 2” PVC pipe. On top, the PVC is connected to Loc Line which allows me to get it close to the blade area. Underneath the table, I collect from just below the blade.
I have a dust collector but the shop vac work best for the scroll saw.
A dust collector gives you high volume at lower suction than a vacuum. My guess is the dust collector is 500 cfm max at 6” of water suction. A shop vac is around 125 cfm and 50-75” of water suction.
The air filter probably a good idea.
I will try to find pics later on.
Nikki
#3 posted 09-18-2016 04:32 PM
- Redoak49
That’s great info. Thanks a lot.
I’ve also considered the dust deputy connected with a shop vac to get the cyclone effect but shop vacs are also very loud. I am trying to find effective dust collection that’s a bit quieter.
I know it won’t be on for long but those shop vacs have a high pitched sound to them. It goes right through me.
I will be wearing a dust mask as well.
Nikki
#4 posted 09-18-2016 04:35 PM
- TheFridge
Ok. That could be done thanks and I’ll check into it.
View bondogaposis's profile
bondogaposis
4727 posts in 2350 days
#5 posted 09-18-2016 04:53 PM
That dust collector for a single tool will have enough power to suck your shorts off. Do like the Fridge suggests and try to get a better filter, you should be able to get it down to .5 micron filtration.
-- Bondo Gaposis
Nikki
#6 posted 09-18-2016 06:54 PM
- bondogaposis
That’s what I’ll do then. Right now I have the one above that one , still in the box, and while its ago 30% more powerful, it’s about 100% louder. It’s a bit of overkill.
Any left over air born dust , the WEN will pick up.
That’s perfect thanks. I’ll take this back tomorrow and get the other model.
Thanks buddy. :D
Redoak49
#7 posted 09-18-2016 07:46 PM
The interesting issue is how to connect a dust collector to the scroll saw. You have a 4” hose….what do you do with it. It will likely suck the projects right off the scroll saw.
Whatever pickup you use, you will need to put some screen with 1/4” screen on it to keep pieces from going in it.
Nikki
#8 posted 09-18-2016 07:59 PM
- Redoak49
I would use one of these that attaches underneath the table. It has an exact size circular piece with 2 holes in it and busy bee has hose adapters
http://www.bigfootproducts.ca/DCS.html
Nikki
#9 posted 09-18-2016 08:07 PM
- Redoak49
Oddly enough when I posted my question on a Scrollsaw only website most agree with your method. I’ve have to find the thread. It’s actually quite brilliant
Nikki
#10 posted 09-18-2016 08:14 PM
Oddly enough when I posted my question on a Scrollsaw only website most agree with your method. I ve have to find the thread. It s actually quite brilliant
Here’s the link :
https://forum.scrollsawer.com/forum/scroll-saw/general-scroll-saw/45170-dust-collection-for-hegner-18vs
- Nikki
Nikki
#11 posted 09-18-2016 08:19 PM
Sorry about that. I messed up that entire post.
Here is a thread about using a shop vac connected to PVC piping towards the top and the bottom.
It does look quite effective but I don’t have $600 for a shop vac.
Redoak49
#12 posted 09-18-2016 08:33 PM
You could use Ridgid shop vac from HomeDepot and add a HEPA filter.
Nikki
#13 posted 09-18-2016 10:04 PM
- Redoak49
Yeah! And I happen to have a Ridgid shop vac.
Would I be able to use one of those dust deputy cyclone things to it.
Hang on and I’ll add a link.
http://www.leevalley.com/en/wood/page.aspx?cat=1,42401&p=69841
View Jim Finn's profile
Jim Finn
2656 posts in 2920 days
#14 posted 09-19-2016 01:30 AM
I killed three shop vacs using them on a scroll saw. One was a new Ridged. Most Shop vacs are not rated to run all that long.
-- Website is No PHD just a DD214 and a GED https://craftingcouple.com/
Redoak49
#15 posted 09-19-2016 01:42 AM
It all depends on how much you use the vac and for how long. Some like Jim Finn do a lot of cutting for selling at various venues and would wear out saws and vacs.
There are a lot of people who use a Ridgid vac with dust deputy successfully in their shops. If you run, you should be aware of the potential issues.
