Working with a lathe for the first time, this maybe a stupid question but how do you remove
« back to Woodturning forum
Forum topic by JoAnneN posted 09-18-2016 01:52 AM 1771 views 0 times favorited 8 replies Add to Favorites Watch
View JoAnneN's profile
JoAnneN
16 posts in 870 days
09-18-2016 01:52 AM
8 replies so far
View Dan Krager's profile
Dan Krager
4163 posts in 2381 days
#1 posted 09-18-2016 02:11 AM
Need more information. Are you trying to remove a tapered spindle insert? Is your headstock spindle open through? If your spindle is hollow like many are, put a 1/2” rod long enough to reach the end of the insert and tap firmly. It should pop right out.
DanK
-- Dan Krager, Olney IL http://www.kragerwoodworking.weebly.com You can allways find three nuts to secure the four bolts you need.
View TheFridge's profile
TheFridge
10334 posts in 1632 days
#2 posted 09-18-2016 03:11 AM
Yup. Should have a hole on the opposite side of the head stock. The lathe should’ve come with a foot long round bar with a knob or something on the end.
View Andre's profile
Andre
2064 posts in 1952 days
#3 posted 09-18-2016 05:31 AM
3 and 1 oil on the fingertip for a lite coat before taper is inserted will make removal much easier! Works great on router collets and shafts too.
View Bob Collins's profile
Bob Collins
2566 posts in 3830 days
#4 posted 09-18-2016 06:22 AM
What was the question JoAnne? Above answers cover the removal of the insert, a rod should have been supplied and only needs a sharp tap with a mallet to remove it. Have fun with the lathe.
-- Bob C, Australia. Your best teacher is your last mistake.
MrUnix
6943 posts in 2345 days
#5 posted 09-18-2016 06:23 AM
Your lathe (PSI Turncrafter Commander, right?) came with a knock-out rod that is used to eject whatever you put in the headstock spindle taper. The manual for your lathe (on page 8) tells how to use it for a spur center, but it’s the same for whatever you put in there – and what you show appears to be the stub end of a MT2-JT33 adapter for use with a drill chuck.
PS: I imagine it’s rather hard turning stuff on that machine while it’s suspended from the ceiling upside down :)
JoAnneN
#6 posted 09-18-2016 02:21 PM
I woke up and tried it, yes it did have a hole, it popped right out! Thanks so much, I was wondering what that bar was. I didn’t get a manual in the box so I have been trying to figure it out. In the past I have only used a scroll saw so this was a learning curve. I didn’t have a grinder or a chuck or realky anything i needed, it was one thing after another. I thought that the barrel trimmer was the center stock, that didn’t fare well. I’m giving myself a break, I’m OK with the mistakes, that’s how I will learn, thanks for all the help with all my questions. I’m ready to turn my first pen, I’ll post a picture when I’m done. Thanks again
Dan Krager
#7 posted 09-18-2016 03:26 PM
Before you create a(nother) dangerous situation where you could get seriously hurt, please download this manual and at least learn the names and uses of the basic parts. This seems to be the appropriate manual for your tool.
Then we can go from there answering your questions. It’s what we do.
DanK
View Woodknack's profile
Woodknack
12369 posts in 2526 days
#8 posted 09-18-2016 03:36 PM
Also find a manual for your phone camera.
