The Perpetual Mortise and Tenon Question,
Forum topic by oldwolf posted 1068 days ago 1080 views 0 times favorited 16 replies Add to Favorites Watch
View oldwolf's profile
oldwolf
100 posts in 1424 days
1068 days ago
Topic tags/keywords: question joining
I was having a discussion with someone the other day, well a debate, and it started up my curiosity, I decided to ask the question here as a kind of impromptu poll
Whatever tools you use to create your mortise and tenon joints, (hand tools, stationary tools, or a hybrid combo) you still have to decide the answer to this question. Which do you typically cut first, the mortise . . . or the tenon?
That is the question I want to hear answered from all of you. It’s kind of like the old “pins or tails” debate. Which side are you on?
Oldwolf
-- Oldwolf - http://insidetheworkshop.blogspot.com/
16 replies so far
86990 posts in 1744 days
#1 posted 1068 days ago
I use a multi router since I’m using loose tenon joinery I cut mortises on both pieces.
View docholladay's profile
docholladay
1258 posts in 1225 days
#2 posted 1068 days ago
I’m kind of with Jim in that I like loose tenon joinery. However, that said, I would definitely cut the mortise first and then the tenon. It’s easy to resize a tenon by either shaving with a shoulder plane or even just sandpaper. It is also easy to glue a shim on to a tenon if you accidentally cut it too small. However, precisely resizing a mortise is not so easy.
-- Hey, woodworking ain't brain surgery. Just do something and keep trying till you get it. Doc
View Gary's profile
Gary
3532 posts in 1599 days
#3 posted 1067 days ago
Here here….I agree with doc
View TheWoodsmith's profile
TheWoodsmith
108 posts in 1087 days
#4 posted 1067 days ago
Mortise first, i dont trust my skills enough to size and place a mortise based on a tenon
-- I know its around here somewhere...
View wseand's profile
wseand
1549 posts in 1208 days
#5 posted 1067 days ago
Mortise than Tenon.
-- Bill - "Freedon flies in your heart like an Eagle" Audie Murphy
TopamaxSurvivor
13192 posts in 1842 days
#6 posted 1067 days ago
Mortise first
27262 posts in 1989 days
#7 posted 1067 days ago
Mortise first. It is relatively easy to take wood off the tenon to get it sized correctly but it is tough to add wood to a mortise that is too large.
View PurpLev's profile
PurpLev
7730 posts in 1815 days
#8 posted 1067 days ago
mortise first. as said – it’s easier to work on the tenon and resize it to fit the mortise than to resize the mortise blindly
View lilredweldingrod's profile
lilredweldingrod
2498 posts in 1273 days
#9 posted 1067 days ago
Yep! I concur, mortise first.
View richgreer's profile
richgreer
4474 posts in 1241 days
#10 posted 1066 days ago
I usually use loose tenons. However, on those occasions when I decide to do a conventional M&T joint I always cut the mortise first. Then I “sneak up” on the size of the tenon using a tenoning jig.
View Domer's profile
Domer
211 posts in 1533 days
#11 posted 1066 days ago
It seems unusual that everyone agrees on almost anything. I agree as well.
I use the Festool Domino most of the time for my M&T, but sometimes resort to the router with some jigs.
Domer
oldwolf
#12 posted 1061 days ago
Thank you everyone for your answers. Domer, I completely agree that it is unusual that agreement was happening, and I kind of feel bad to be the one to break up the togetherness.
I do infact cut my tenons first, I find sneaking up easier by paring the walls of the mortise, I was inspired enough by this question and by the seeming oddness that I seem to be that I wrote a article for my blog about the question and the methods I use when I make my M&T joints
you can check it out at my blog Inside The Oldwolf Workshop, and feel free to leave me a comment,
infact someone else out there has to cut the tenons first, I can’t be the only one! please speak up and help me feel better about myself :)
Cheers
Oldwolf
View MostlyHarmless's profile
MostlyHarmless
21 posts in 1060 days
#13 posted 1059 days ago
I haven’t had a project that uses M&T joints yet, but I’d think that doing the tenon first would be the easier way to go. Only because you should be able to stencil the mortise around the tenon you already made. I can’t really see any way to stencil a tenon around an already made mortise. Is there a trick to this, or do you just go off measurements and trial’n error?
-- If there's anything more important than my ego around, I want it caught and shot now.
View Moron's profile
Moron
4433 posts in 2060 days
#14 posted 1059 days ago
mortise first but any man who cant cut the mortise after the tenon is only half the woodworker he thought he was.
View CaptainSkully's profile
CaptainSkully
1187 posts in 1725 days
#15 posted 1055 days ago
I have found that cutting the mortise first (I’ve hacked them out by hand and with an MDF jig and a spiral upcutting bit) allows me to make the tenons with a stacked dado head on the table saw a little snug, then I use a sanding block to clean up the saw marks and dial in the fit.
If you’re exposing the ends of your through tenons, like I often do with Arts & Crafts furniture, it’s very important to get the fit nice and tight, since it will be the first place your eye will go. If I was paring down my mortise, I would be afraid to make a goof that would show. Plus, I’ve got to bevel the ends of my tenons anyway, so I might as well clean up the shoulders while I’m at it.
-- You can't control the wind, but you can trim your sails
