Is this cherry blotching?
Forum topic by ColonelTravis posted 09-16-2016 09:51 PM 1305 views 1 time favorited 27 replies Add to Favorites Watch
View ColonelTravis's profile
ColonelTravis
1932 posts in 2098 days
09-16-2016 09:51 PM
Topic tags/keywords: cherry blotch
I read about it but never see pictures. Making a little fence for my plow plane, out of some cherry from a batch I bought a while back. Is this typical cherry blotching?
I put on two coats of Minwax Antique Oil finish. Before I make anything substantial from this stuff I want to make sure I know what’s going on.
27 replies so far
View Aj2's profile
Aj2
1885 posts in 2002 days
#1 posted 09-16-2016 10:01 PM
Too me it looks like a area that did not get sanded down evenly.
Aj
-- Aj
ColonelTravis
#2 posted 09-16-2016 10:47 PM
It’s hand planed, card-scraped, sanded, buffed, baby butt smooth!
View Kirk650's profile
Kirk650
576 posts in 952 days
#3 posted 09-16-2016 11:08 PM
Looks like blotching to me. That said, some blotching isn’t always that bad on cherry.
View BurlyBob's profile
BurlyBob
5986 posts in 2469 days
#4 posted 09-17-2016 01:47 AM
I’m curious. Will that even out as it darkens with age? I have no experience with cherry. I’ve been accumulating a few pieces and would like to learn from this thread.
View jwmalone's profile
jwmalone
769 posts in 906 days
#5 posted 09-17-2016 01:57 AM
I’m not an expert on cherry, but I’ve seen some blotchy stuff before on cherry and it doesn’t even out with time. We refinished some cabinets for a lady. They were cherry, the finisher/painter done a horrible job. Told her it would even out in a few months. Well a year latter still look like crap and guess what he was unable to be found. So we striped it and redone it.
-- "Boy you could get more work done it you quit flapping your pie hole" Grandpa
View bandit571's profile
bandit571
21787 posts in 2887 days
#6 posted 09-17-2016 02:10 AM
Sometimes, IF parts of a Cherry board sees more sunlight than the rest, like a shadow. Sunlight will darken Cherry.
View bondogaposis's profile
bondogaposis
5094 posts in 2555 days
#7 posted 09-17-2016 01:14 PM
Yes, that is characteristic cherry blotch.
-- Bondo Gaposis
View Aj2's profile
Aj2
#8 posted 09-17-2016 01:41 PM
It s hand planed, card-scraped, sanded, buffed, baby butt smooth!
- ColonelTravis
Darn wrong again,One of these days I’ll get one right. :)
-- Aj
View distrbd's profile
distrbd
2252 posts in 2650 days
#9 posted 09-17-2016 02:57 PM
I get that blotchy look on some of the stuff I ‘ve built,the only thing that made a difference in evening out the color was to rub some of the original finish (Tung oil in my case) on the lighter parts but it has to be re-applied after a year or so.
-- Ken from Ontario, Canada
View RogerM's profile
RogerM
799 posts in 2603 days
#10 posted 09-18-2016 01:22 AM
Indeed, that is cherry blotching. Solve it by sanding to around 220 grit. Now, starting with bare sanded wood put a coat of dilute sealer on it (that would be 3 parts of alcohol to one part of Zinser Bulls Eye Seal Coat). Allow this to dry for at least an hour then put your stain ( I usually use Minwax Cherry Stain) on it or in your case the Minwax Antique Oil finish. Rub this out with fine steel wool #0000 or 800 or higher grit sandpaper wax and buff. Good Luck! Hope this helps.
-- Roger M, Aiken, SC
View avsmusic1's profile
avsmusic1
273 posts in 889 days
#11 posted 09-18-2016 02:09 AM
Gerald Thompson
1121 posts in 2438 days
#12 posted 09-18-2016 01:01 PM
+1 on Charles Neil’s blotch control.
-- Jerry
ColonelTravis
#13 posted 09-18-2016 03:49 PM
thanks for the input!
View pintodeluxe's profile
pintodeluxe
5798 posts in 3017 days
#14 posted 09-18-2016 06:17 PM
1+ Roger M’s comment. 3:2 D.A. to shellac seal coat works great. For heavily blotching cherry I use a 50/50 mix as a pre-stain conditioner.
Kirk650
#15 posted 09-18-2016 10:47 PM
Over the years I’ve used all sorts of blotch controllers, and nothing ever worked real well – until I bought and tried the Charles Neil blotch control material. I’m now in the process of staining (dark) some Hard Maple, and the staining is going great. The test staining prior to buying the blotch controller went badly. Nasty blotching.
I don’t work for Charles, and what I’ve seen and stated comes from my personal use of his product. Not saying the shellac approach doesn’t work, so do as you wish.
