what edge guide to use with Dewalt 611PK router?
Forum topic by distrbd posted 09-16-2016 03:46 PM 2393 views 0 times favorited 8 replies Add to Favorites Watch
View distrbd's profile
2252 posts in 2376 days
09-16-2016 03:46 PM
I have been looking for a router edge guide that is either specifically made for this model (DW611PK) or at least fits in it without any issues, as far as my search shows, there are two available on Amazon for this particular router:
The first option is the one I prefer but a couple of reviewers complained about it not fitting the DW611 router, I was wondering if anyone who owns this router uses this edge guide and if so, do you have any problems with it ?
Is there a third option? maybe a different edge guide from a different router?
I’d appreciate all comments.
-- Ken from Ontario, Canada
8 replies so far
View pintodeluxe's profile
5587 posts in 2743 days
#1 posted 09-16-2016 04:49 PM
I have the 6913 that I use with my 618 router. I also have the 611 and two other edge guides. One is a Bosch and one is a Porter Cable. I was thinking that the Porter Cable 42690 edge guide fit the 611, but I would have to double check. The DNP 618 is the edge guide designed for the 611 router (confusing numbering system that the DNP 618 doesn’t go with the 618 router).
I’ll check it out tonight and get back to you.
This video review appears to show the 6913 edge guide working with the 611 plunge base… The 6913 is a nice guide.
View WisBob's profile
4 posts in 547 days
#2 posted 09-16-2016 05:40 PM
I use the DW6913 with my 611 plunge base. Very handy for cutting mortises.
View SteveT's profile
25 posts in 1173 days
#3 posted 09-16-2016 06:41 PM
Has anyone used the M-Power CRB7? A lot more expensive though.
I have a Dewalt 618 router and this base/guide is suppose to work with the router.
6472 posts in 2129 days
#4 posted 09-16-2016 06:53 PM
I don’t have that router, but B&D makes a pretty nice multi-purpose router guide that has fit on just about every other router I’ve thrown it at (it comes with it’s own base plate)... and it can be found for about $10-$15 online.
Black & Decker 76-234 Deluxe Router Guide
#5 posted 09-16-2016 07:47 PM
I asked in another thread (another WW site) about what is considered the guide designed for 611(and probably a bunch of other dewalt routers) and to my surprise it is the second option which is( as Pinto mentioned) DNP618 but when I search for a “edge guide for DW611” I get DW6913.
Pinto , wisBob,Steve, thank you for the info, Now I know for sure the 618 will work.
Mr Unix, the B&D looks like a well made guide,I have read a lot praises about it, and the Bosch guide but I’m thinking a universal guide like that is more likely to have some flex with 611, I just want to buy the right one once and for all,unless I know for sure it’ll fit a 611.
Thanks for all your comments / help.
#6 posted 09-18-2016 04:00 AM
Sounds like you found what you needed with the 6913. For anyone else looking, the Porter Cable 42690 edge guide also fits the 611 plunge base.
#7 posted 09-18-2016 01:29 PM
Pinto, thanks for getting back to me, it’s good to know that the PC-42690 also fits the dewalt,it is also a circle cutting guide which is a plus, overall a well designed guide.
I haven’t ordered any of the 3 you have mentioned but that Porter Cable guide seems to be the winner, it’ll fit my PC router as well, thank you for the suggestion.
View 1950Hudson's profile
1 post in 329 days
#8 posted 04-22-2017 11:17 PM
Joined up just to say thanks for this thread! I had this question as I wanted to find a guide that would work with both the 611 and my ancient series 1 PC6902.
Asked Woodcraft but they said it wouldn’t work. Asked Rockler but they said it wouldn’t work.
Asked the Dewalt Service center and they assured me it wouldn’t work.
BUT my B’S detector didn’t like those answers so, if I got the pictures posted correctly, you can see for yourself. PC edge guide attached to Dewalt plunge base, no problem. Parts fit exactly and tightened securely. Cut 18” circle no sweat.
Thank You Pinto
