Forum topic by Robin1 posted 09-15-2016 05:23 PM 455 views 0 times favorited 0 replies Add to Favorites Watch
View Robin1's profile
136 posts in 1420 days
09-15-2016 05:23 PM
Topic tags/keywords: sale table saw drill press new porter cable delta new york ny upstate rochester syracuse tools
I have 2 larger floor machines that I need to sell off. One is a Delta table saw. The other is a floor model Porter Cable Drill Press. The Table saw is about 6 months old, the drill press 2 months. I need to sell off before winter as it looks like I may be moving in the Spring. The Saw was about $650- looking for $475. Drill press was $375- I’d like to get $300. Specs below. I am in Upstate NY between Rochester and Syracuse. Thanks.
X-Y axial projecting laser lines for accurate pre-alignment of drill location
4-in spindle travel provides extra drilling capacity
Dual hubs provide for left or right side positioning of handles on drill head
12 operating speeds from 300 – 3100 RPM for wood or metal drilling and sanding operations
Cast-iron work table, surface tilts up to 45° right or left for bevel drilling. Oil channel around edges for metal drilling
Rack and Pinion work table elevation feature for quick and accurate height adjustments
Built-in, adjustable work lamp (max. 40 watts) for better illumination of work area
Depth adjustment gauge allows accurate drilling of repetitive depth holes
13-Amp 10-in Table Saw
Cast iron table with T-square 3-point locking rip fence for precise, smooth, clean cuts – accurate to 1/64-in
13-amp dual voltage (120/240-volt), totally enclosed fan cooled (TEFC) induction motor, for ripping thick stock or the most challenging dados
Integrated dust collection system, with 2.5-in shrouded dust port, easily connects to a wet/dry vacuum or other dust collection systems
Tubular stand, with easy lift caster system, assembles easily – requires fewer parts than traditional contractor saw stands
Locking bevel and height adjustment wheels for secure repetitive cuts
Steel rails with spreader insures accurate, repeatable rip cutting of even the widest stock
Built-in arbor lock allows for quick and easy blade changes
Standard 3/4-in wide, T-slotted, miter gauge slots for after market accessories like feather boards
0 replies so far
