Bosch router with porter cable dovetail bit
Forum topic by PaulHWood posted 09-15-2016 02:56 PM 506 views 0 times favorited 3 replies Add to Favorites Watch
View PaulHWood's profile
424 posts in 2184 days
09-15-2016 02:56 PM
Topic tags/keywords: router router bits porter cable bosch
Why when I put my porter cable supposed 1/2” dovetail bit into my bosch supposed 1/2” collet is it such a tight fit and near impossible to get out.
Any tips for making this smoother
-- -Paul, South Carolina Structural Engineer by trade, Crappy Woodworker by choice
3 replies so far
View bondogaposis's profile
4632 posts in 2282 days
#1 posted 09-15-2016 04:55 PM
I have a 1/4” collet on my Bosch router that I have to tap the bits in and out of. I thought it would eventually break in, but it has been years. I’m too cheap to spring for a new collet, so I reach for the hammer and drift pin every time I need to change bits when using this collet. Doesn’t really solve your problem, but at least you know you are not alone. Is that the only bit that has a problem? Try to narrow down whether it is the bit or the collet. The solution would be replacement of the offending item.
-- Bondo Gaposis
View Kirk650's profile
524 posts in 680 days
#2 posted 09-15-2016 05:12 PM
You might try a good rubdown of the router bit shaft with steel wool. That worked on some router bits I was having trouble with. That and a light coat of oil might help.
I was just using those same bits in the same router for the same purpose. It all worked great, but MAN what a cloud of sawdust I generated.
I doubt I’ll ever again use the full PC 4212 Dovetail jig as designed. I got a copy of the supplemental manual showing how to use the template for through dovetails on unlimited width boards. Once I got that set up and understood how to use it, the dovetails came out great. It’s a heck of a lot simpler than using the 4212 as designed. That said, if the PC4212 offered some type of dust control, I’d probably use the jig again.
#3 posted 09-16-2016 01:28 PM
No problems with the 1/4” collet and bits, but I have two of the bosch routers so I tried both 1/2” collets I have and same thing. Will try steel wool.
kirk, I think you could fashion a dust collector for the 4212, and I am thinking of it as I just did 24 draws for this project and it does through some wood around.
And yes bondo, misery loves company
