MDF glue up question
Forum topic by BobD posted 06-16-2010 04:41 PM 1099 views 0 times favorited 3 replies Add to Favorites Watch
View BobD's profile
BobD
52 posts in 3408 days
06-16-2010 04:41 PM
I want to laminate two MDF “pre-primed” boards together to make a vertical side panel. I will use Titebond II yellow glue and screws to fasten them together. Since the boards are pre primed with an undercoater, will that have an affect on the glue’s holding power?
San Diego
-- Bob, San Diego
3 replies so far
View ajosephg's profile
ajosephg
1880 posts in 3556 days
#1 posted 06-16-2010 07:00 PM
I’d recomend calling Titebond’s technical service and get an expert opinion.
-- Joe
View PurpLev's profile
PurpLev
8535 posts in 3643 days
#2 posted 06-16-2010 07:05 PM
generally speaking – yes , as the primer usually seals the material – glue, stain, and finish will have a hard time penetrating it (which is what it’s purpose really is).
but as Joe stated- TB would be able to give you the low down on how much of a problem this would be with TB2
View wseand's profile
wseand
2796 posts in 3037 days
#3 posted 06-16-2010 07:09 PM
I would think you will want to sand and clean any surface you want to glue. And as Joe suggested call Titebond they are quite helpful I have talked to them.
