Mallet
Forum topic by lazyfiremaninTN posted 328 days ago 149 views 0 times favorited 2 replies Add to Favorites
lazyfiremaninTN
464 posts in 481 days
328 days ago
I’ve always heard that you appreciate tools that you make or restore yourself more. With that being said, I have a question.
Is it possible to craft a mallet from a single log?
I had the idea to take a “saved” piece of firewood and cutting/carving to fashion a mallet from it.
Any ideas/ suggestion/ comments would be greatly appreciated.
Adrian
View eddiebyrd's profile
eddiebyrd
2 posts in 327 days
327 days ago
Adrian,
I just delivered this maul to an acquaintance who needs one for a Masonic ceremony…
It is such a neat concept that I intend to make one for myself.
View Red Headed Merganser's profile
751 posts in 702 days
327 days ago
What kind of wood is it? Some are going to be better than others… oak wouldn’t be bad; maple might be better. As far as domestic woods go, osage orange or iron wood are going to be the woods of choice.
Here’s mine:
http://lumberjocks.com/projects/345
Look at the transition between the mallet head and the handle; see how it makes a smoother transition? I think I get more control (and it feels more comfortable) when I put my thumb up on that lip using my mallet. I’ve tried other mallets that have a much harder transition line (a 90 degree edge, even) and don’t like them nearly as much.
A friend of mine, who passed away this year, helped me make it. We based that transition design on a lignum vitae mallet he had in his shop and had used for years. (I have that mallet in my shop, now, too.)
A high-gloss poly might look good, but you don’t want that on a mallet you’re going to use. For one thing, it is a surface finish and it won’t last if you’re pounding chisels with it. You also want a finish that won’t slide off the end of the chisel when you strike it.
For my finish, I took an old metal coffee can, filled it a third of the way with BLO, and set the mallet into it, head down. I let it soak for a day or so, then pulled it out and wiped it down (head and handle) and let it dry and then applied another coat. I did that for two weeks straight, if I remember right. Every now and again I’ll give it another coat, to keep it well-seasoned.
-- Ethan, http://www.merganserwoodworks.com, http://greystonegreen.blogspot.com/
Bookmark And Share This Page
