Hitachi M12 V basepate screw removal
Forum topic by JKN posted 09-15-2016 12:05 AM 311 views 0 times favorited 1 reply Add to Favorites Watch
View JKN's profile
JKN
8 posts in 565 days
09-15-2016 12:05 AM
Guys
I have a Hitachi M12 VE and mounted it in my router table with a phenolic plate. I got longer screws to mount it, don’t recall the size
I need to use it free hand and want to remove the phenolic base and put the factory supplied base back on.
As happened in the past the last screw stripped. I bought at # 2 Ryobi screw extractor and can’t get it to work.
I have my original M12V, but it’s not working due to variable speed failure
Any idea how to remove this last screw? I ran into this same problem w my M12V, but was able to get the screw out. I really wish Hitachi would include decent screws with these routers
Any advice appreciated
thanks
John
1 reply so far
17193 posts in 1725 days
#1 posted 09-15-2016 12:17 AM
Didn’t you say you got new longer screws? Hat screws did you get. Are they Phillips? Are they #2 or #3 heads. Make sure you’re using the right size screwdriver. Can you try using an impact driver to get them out? Tap the bit into the screw head with a hammer first.
