Accidental scraper
« back to Hand Tools forum
Forum topic by Kirk650 posted 09-14-2016 01:10 AM 732 views 0 times favorited 2 replies Add to Favorites Watch
View Kirk650's profile
Kirk650
521 posts in 625 days
09-14-2016 01:10 AM
I have a good supply of dedicated scrapers, but when I need to remove dried glue from glued up panels, I have a black plastic handled paint scraper that I normally use. If you don’t have one, I’m sure you seen them in the paint aisle at Lowes or HD, the scraper has a replaceable 4 edge cutter head. You use them till dull and then remove the screw and rotate the blade to a new edge. Well, it occurred to me one day than rather than rotate the cutter head, maybe I should just sharpen the dull edge. I had a flat file at hand, so I did. It worked great, and was far superior to the standard edge. It actually functions quite well as a real wood scraper. I haven’t rotated the cutter edge for a year or two. I just refile and slightly roll the edge with the file.
2 replies so far
View dbw's profile
dbw
190 posts in 1513 days
#1 posted 04-24-2017 11:32 AM
Saving $ is saving $...
-- measure 3 times, cut once
View LittleShaver's profile
LittleShaver
242 posts in 496 days
#2 posted 04-24-2017 01:31 PM
I suffer from male pattern cheapness according to my wife.
I figured out the file to sharpen trick many years ago and have used it so many times that I actually had to buy a new blade. There was nothing left to sharpen.
The new blades came in a two pack, should be a lifetime supply at this point.
-- Sawdust Maker
