need a specialty fastener
Forum topic by mzimmers posted 06-15-2010 06:39 PM 1172 views 0 times favorited 9 replies Add to Favorites Watch
View mzimmers's profile
mzimmers
212 posts in 4155 days
06-15-2010 06:39 PM
Topic tags/keywords: press wood nut question
Hi, guys -
It’s been awhile…hope everyone’s doing well.
I’m building a small press for gunsmithing purposes. I’m going to use 5/8” steel rod as the bolt, and I need to a nut that I can make captive to the frame of the press. Not knowing what such a nut is called (if it even exists) makes googling difficult. I suppose I can just make one from a scrap of steel, by threading it in the middle and drilling fastening holes in the corners, but I thought I’d ask if anyone here knew of a source for something like this.
Thanks.
-- M. Zimmers
9 replies so far
16281 posts in 4458 days
#1 posted 06-15-2010 06:46 PM
I assume you are looking for a threaded insert.
http://www.rockler.com/product.cfm?page=362&filter=threaded%20insert
You might have some difficulty finding one that large, though.
mzimmers
#2 posted 06-15-2010 06:54 PM
Yeah, that’s the idea, but (as you suggested) they don’t seem to come any bigger than 3/8”. I also don’t need the fastener to be embedded in the press; a surface mount of the nut is OK.
Any other ideas? Otherwise, I’ll just make a couple.
-- M. Zimmers
View Peter Oxley's profile
Peter Oxley
1426 posts in 4114 days
#3 posted 06-15-2010 06:57 PM
Yeah, a threaded insert might work, or a T-Nut (teenut) – you should be able to find either at a hardware store in the little bins. Or maybe a heli-coil might work – you can find them at an auto parts store.
-- http://www.peteroxley.com/woodworking -- http://north40studios.etsy.com --
View Michael Murphy's profile
Michael Murphy
453 posts in 3245 days
#4 posted 06-15-2010 06:57 PM
Threaded inserts will be hard to find in that size. I would think just drilling and tapping a hole in a piece of steel would be the way to go. Or something like this?
-- Michael Murphy, Woodland, CA.
mzimmers
#5 posted 06-15-2010 07:02 PM
Hmm…that press screw is an interesting idea. I wonder if the square foot screws off.
Thanks for the suggestions, guys.
-- M. Zimmers
#6 posted 06-15-2010 07:13 PM
It also occurred to me that a galvanized wall flange would suit your needs perfectly if pipe threads were okay.
Michael Murphy
#7 posted 06-15-2010 07:29 PM
Pipe threads generally taper so they can form a tight joint. There are Electrical connectors that don’t use tapered threads. Rigid conduit connectors aren’t tapered I don’t think. Or you could get a small cast flange and try tapping it to the size straight thread you want.
View ddockstader's profile
ddockstader
158 posts in 3501 days
#8 posted 06-15-2010 09:35 PM
Try looking for a T-nut. They’ll go up to 5/8” and larger, although large ones are a little more difficult to find.
mzimmers
#9 posted 06-15-2010 10:23 PM
Thanks for the ideas, guys. You collectively confirmed to me that there wasn’t really any easily obtained off-the-shelf answer for this, so I just made myself a couple, from 3/8” steel bar stock.
Now, I have to figure out how to attach a handle to the threaded rod I’m using, but, as that’s a metal-joining issue…that’s a question for a different forum.
Thanks again.
-- M. Zimmers
