Replacing jointer feet with caster wheels?
Forum topic by Dagobah posted 09-13-2016 04:51 PM 1684 views 0 times favorited 14 replies Add to Favorites Watch
View Dagobah's profile
Dagobah
71 posts in 812 days
09-13-2016 04:51 PM
I was watching this video where he mentions using 3/8” threaded casters on the bottom of his Ridgid jointer. He ends up making a stand, but I thought it was an interesting idea.
I’ve got the same jointer and end up dragging it around the garage every night. Amazon has multiple options ranging in price. The jointer is 220lbs total, plus the pressure I’d be applying to stock, so ideally 80lbs per caster min.
Has anyone has gone this route?
14 replies so far
View splintergroup's profile
splintergroup
2313 posts in 1371 days
#1 posted 09-13-2016 06:59 PM
I made a mobile base for my Jet 6”.
If I had it to do again, I’d do it differently.
My problem is even with locking casters, they still ‘wiggle’ around. I’d be better off replacing the two casters on one end with non-swivel wheels and the casters on the opposite end with feet.
To move it around, just lift the end with the feet, much like pushing around a wheelbarrow. When set back down, it should be stable.
View syenefarmer's profile
syenefarmer
506 posts in 3230 days
#2 posted 09-13-2016 07:16 PM
The Ridgid 6” jointer is very top heavy. I would think that just putting casters on the stand legs would invite a tip over the first time the wheels hit an obstruction on the floor. You’d be better off putting the casters on a wider piece of plywood and then bolting the jointers legs to the plywood.
View BorkBob's profile
BorkBob
127 posts in 2842 days
#3 posted 09-13-2016 07:55 PM
My 8” jointer has built in tricycle wheels. I park it against a wall and it was a hassle to get it out in the open. I set it on http://www.harborfreight.com/movers-dolly-39757.html. I’m tall so the added height is not a problem.
-- Please Pray for Our Troops / Semper Fi / Bob Ross / www.theborkstore.com
View MT_Stringer's profile
MT_Stringer
3175 posts in 3380 days
#4 posted 09-13-2016 08:00 PM
My 6 inch Jet came with a mobile base. Two casters are fixed and a third swivels. Yep, at times it can move around when I am working it hard.
View Kirk650's profile
Kirk650
567 posts in 898 days
#5 posted 09-14-2016 01:18 AM
Everything in my workshop has wheels except for the jointer. I carefully chose where to put the jointer and have never had to move it. I do move other wheeled apparatus to allow room to use the jointer with long boards. I even had to open the front door one fall weekend to allow room to run 7 foot bed posts over the jointer.
View lennyk's profile
lennyk
32 posts in 981 days
#6 posted 09-14-2016 01:26 AM
Have same 6” ridgid 200lb
i welded up a base out of 1 1/2” angle steel and put hf wheels on them. Two straight and two swivel.
The two straight are on the out feed side.
I usually just stick a piece of 1/2” rod under the wheels to jam them.
View Picken5's profile
Picken5
261 posts in 2841 days
#7 posted 09-14-2016 03:52 AM
I’ve tried lockable casters a few times and they didn’t work for me. The tool rocked a bit which I found annoying. And sometimes one of the locking casters would come unlocked at inconvenient times. So I got a mobile base for my older 6” Delta jointer a few years back. No regrets at all. It installed easily and works great. If I recall, it was an HTC that was rated at 500 lbs. I think my jointer weighs about 250 lbs which is probably pretty close to what your Rigid jointer weighs.
-- Howard - "Time spent making sawdust is not deducted from one's lifetime." - old Scottish proverb
View Holbs's profile
Holbs
1960 posts in 2178 days
#8 posted 09-14-2016 04:03 AM
i went mobile base. $55… was an easy decision.
-- The Carpenter Bee is derived from the Ancient Greek word wood-cutter
lennyk
#9 posted 09-14-2016 11:02 AM
wheels are great for everything, my stuff is all outdoors so every week I push everything aside and
hose down the floor.
View OggieOglethorpe's profile
OggieOglethorpe
1276 posts in 2259 days
#10 posted 09-14-2016 01:03 PM
A few wedges can lock anything in place, wheels or not…
Roll it into place, tap them in, nothing is going anywhere until you take them out.
View PaulHWood's profile
PaulHWood
439 posts in 2402 days
#11 posted 09-14-2016 02:05 PM
I started with that and did not like it as the base is very flexible. I used a harbor freight kit, some steel tubing (stolen form another LJer), and a plywood base that I could bolt the jointer too.
http://lumberjocks.com/reviews/5306
-- -Paul, South Carolina Structural Engineer by trade, Crappy Woodworker by choice
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2519 days
#12 posted 09-14-2016 02:12 PM
When I got my old 8” Yates jointer back to my garage, I put it on a HF furniture dolly as a temporary place until I made/purchased a mobile base for it. It still sits on that dolly, and I chock the wheels with scrap when I wheel it out for use.
View HokieKen's profile
HokieKen
6299 posts in 1288 days
#13 posted 09-14-2016 03:32 PM
I made a “dolly” out of 2×4s and plywood and put double locking casters on it. Casters are great but the narrow footprint made it too unstable. So, I made some wedges that I put under the dolly when I’m using it and it works great.
-- Kenny, SW VA, Go Hokies!!!
splintergroup
#14 posted 09-14-2016 08:21 PM
- OggieOglethorpe
I use some thin cutoff strips as wedges (about 1/4” x 1/4” triangle). It works, but a major hassle. A swing-down wedge or other movement stopping device would be better. If it isn’t convenient to use, I find myself not using it.
