Mounting t-track in MDF?
Forum topic by live4ever posted 06-15-2010 08:58 AM 3332 views 0 times favorited 5 replies Add to Favorites Watch
View live4ever's profile
live4ever
983 posts in 2916 days
06-15-2010 08:58 AM
Topic tags/keywords: question t-track mdf router fence jig
I’m making a router fence for my table saw extension router table. The faces are MDF. I was planning on placing t-track in the front face. Do I have to glue/epoxy/cement it? I know screws don’t hold very well in MDF but I don’t like to epoxy my t-tracks down if I can help it…
5 replies so far
View Sawdust4Blood's profile
Sawdust4Blood
397 posts in 2928 days
#1 posted 06-15-2010 09:47 AM
you might consider drilling holes all the way through the MDF and then using machine screws with washers and nuts rather than screws. That will prevent pull out without having to epoxy your t-tracks.
-- Greg, Severn MD
live4ever
#2 posted 06-15-2010 10:01 AM
Ah good idea Greg! I will have to check and see if that interferes with the aluminum angle support but hopefully it should be ok…
View Kent Shepherd's profile
Kent Shepherd
2718 posts in 3192 days
#3 posted 06-15-2010 08:00 PM
Greg—good answer. I had to do that on my drill press table. The screws pulled out under medium pressure.
-- http://shepherdtoolandsupply.com/
Sawdust4Blood
#4 posted 06-15-2010 10:37 PM
Kent—my drill press table was exactly where I got the idea. It was the only way to prevent pull out and get the kind of pressure needed to hold pieces in place. Seems to be a common issue on that application.
-- Greg, Severn MD
View Gary Lucas's profile
Gary Lucas
74 posts in 2815 days
#5 posted 06-15-2010 10:40 PM
I use T-track on the MDF back of the miter saw extensions. I did what others did. I drilled all the war thru the MDF and used a screw, lockwasher, flatwasher and nut. It works great.
-- Go create sawdust
