What sanding media will get the best results with the least abrasion to metal.
« back to Hand Tools forum
Forum topic by BurlyBob posted 09-12-2016 02:52 AM 1066 views 0 times favorited 11 replies Add to Favorites Watch
View BurlyBob's profile
BurlyBob
5239 posts in 2168 days
09-12-2016 02:52 AM
What media would best to use in my sanding cabinet to clean up hand planes? I know some things will etch the metal. I’m pretty set on glass beads unless someone can recommend something better. I might have a source for free coal slag, but I have to work that source a little more. My concern is damaging/etching the metal unnecessarily.
11 replies so far
View jbay's profile
jbay
2035 posts in 802 days
#1 posted 09-12-2016 03:14 AM
Walnut shells
-- If anyone would like to see my Portfolio, PM me and I would be glad to send you the link.
View mahdee's profile
mahdee
3843 posts in 1670 days
#2 posted 09-12-2016 10:43 AM
0000 steel wool might be an option.
-- earthartandfoods.com
View Jim Jakosh's profile
Jim Jakosh
20068 posts in 3008 days
#3 posted 09-12-2016 11:02 AM
I’d use 400 wet/dry sandpaper with water or oil to clean them up.
Jim
BurlyBob
#4 posted 09-12-2016 01:04 PM
I’ve used wet/dry paper and a brass wheel on a grinder. I was thinking the sanding cabinet would be the way to remove the japanning. I’m still researching that option.
View Bill White's profile
Bill White
4853 posts in 3863 days
#5 posted 09-12-2016 02:48 PM
I often use soda blasting. Inexpensive, enviro-safe, and effective.
Bill
-- bill@magraphics.us
View waho6o9's profile
waho6o9
8099 posts in 2480 days
#6 posted 09-12-2016 03:30 PM
Soda blasting
View oldnovice's profile
oldnovice
6543 posts in 3271 days
#7 posted 09-12-2016 04:47 PM
Many machine shops use 3M Scothbrite pads
I learned this when I was working to get some very prototype ink jet printer heads machined as there were some delicate features that could not be scratched or deformed.
He handed me a 3M ScotchBrite pad and added this is all we ever use.
My son, the CNC machinist who has worked at three different shops, said all the shops where he has worked used 3M Scotchbrite pads for deburring, tool, and part cleanup.
View Dark_Lightning's profile
Dark_Lightning
3067 posts in 3012 days
#8 posted 09-13-2016 02:14 AM
Japanning is just paint. Have you tried MEK? That won’t touch the metal, at all.
-- Random Orbital Nailer
waho6o9
#9 posted 09-13-2016 02:16 AM
Methyl
Ethyl
Ketone
View Grumpymike's profile
Grumpymike
2214 posts in 2218 days
#10 posted 09-14-2016 08:46 PM
I have never removed the japanning from any of the planes that I have restored, I have found them intact enough to make a good user the way I bought them. But that being said, I give them a good soak in ‘Evaporust’, then I lap the sole in and while I have the 220 grit out (on a granite slab)I also lap the sides in as well.
That process makes them look pretty new, and shiny.
If you want to remove the Japanning, I go with Bob White’s suggestion, I would soda blast them, and being that you have a blasting cabinet, make a trip to Sam’s or Costco and pick up a few 5 pound bags … they are cheap compared to glass beads or sand.
-- Grumpy old guy, and lookin' good Doin' it. ... Surprise Az.
View McFly's profile
McFly
270 posts in 930 days
#11 posted 09-15-2016 08:08 PM
Methyl ethyl ketone rocks.
