Solid panel thickness for doors
Forum topic by Zach117 posted 06-14-2010 08:13 PM 1420 views 0 times favorited 2 replies Add to Favorites Watch
View Zach117's profile
Zach117
19 posts in 3061 days
06-14-2010 08:13 PM
I was wondering if there is a standard thickness to use for solid wood panels in cabinet doors. I have seen anywhere form 1/4”-5/8”. I am talking about shaker style, inset frame and panel doors. Does this depend on the width and height of the panel?
2 replies so far
View Kent Shepherd's profile
Kent Shepherd
2718 posts in 3287 days
#1 posted 06-14-2010 11:08 PM
I’m not sure there is a standard measurement for anything in the woodworking industry.
To me, a shaker door has a flat, not a raised panel. We typically use 1/4” plywood for the panels, but sometimes the customer wants solid wood. Then, to get the same flat panel look, we raise the panel to the back. I’m not sure what the finished thickness of the panel is, but it is the measurement from the front of the groove to the back of the door. Of course that depends on the position of the groove in the frame and how thick the frame is. We make the panel flush with the back of the door.
Hope this helps
Kent
-- http://shepherdtoolandsupply.com/
Zach117
#2 posted 06-14-2010 11:41 PM
Yes, Kent I am talking a about a solid flat panel. I have seen the raised panel flipped to the back, I guess I need to go in that direction. The thickness of raised panel doors. Thanks.
