Need help with some old tools.
Forum topic by heavyelectrician posted 06-14-2010 06:37 PM 1444 views 0 times favorited 13 replies Add to Favorites Watch
View heavyelectrician's profile
heavyelectrician
14 posts in 2906 days
06-14-2010 06:37 PM
Topic tags/keywords: question
I like old tools, especially inherited tools. So i have inherited some nice old Disston saws. They have been in storage for many years so you can imagine the discoloration and some rust. So how do i get the saw nice and smooth again, and hopefully somewhat silver. I’m not expecting them to gleam like a mirror but now they are brown.
-- You hold onto friends by keeping your heart a little softer than your head
13 replies so far
View Don Newton's profile
Don Newton
714 posts in 3586 days
#1 posted 06-14-2010 06:52 PM
I have never used it personally but I’ve heard that Naval Jelly works wonders on rusted tools.
-- Don, Pittsburgh
View David Craig's profile
David Craig
2137 posts in 3076 days
#2 posted 06-14-2010 07:10 PM
I have used Naval Jelly to take the rust off of some old tools that a friend gave me. He found them in a garage attic. Many items were crusted over and I was able to find the original finish and make them usable again. Many folks here have had much success with a product called evapo-rust. The product requires little scrubbing and pretty much brings items to a “like new” state after a dip.
David
View uffitze's profile
uffitze
199 posts in 2922 days
#3 posted 06-14-2010 08:14 PM
I’ve used WD40 and some wet/dry sandpaper with good results.
Take the handle off first. Get a file and sharpen the saw when you are done.
Look up the Norse Woodsmith’s blog (dunno if he’s on this site) ... good info on saw restoration (and old hand tools in general).
heavyelectrician
#4 posted 06-14-2010 08:31 PM
Ok now where can i find Naval Jelly and evapo-rust?
uffitze, i tried the WD40 and sand paper ( my typical quick fix for everything WD40, duct tape and bailing wire) and i have had good results removing rust this way. But with these saws after over a half hour of work the small spot i was experimenting with was light brown and i was stained dark brown. Then my wife was trying to get the rust out of my clothes, somehow it got everywhere. She did a great job with my clothes, wonder if i can get her to clean the saws.
View chrisstef's profile (online now)
chrisstef
17310 posts in 2973 days
#5 posted 06-14-2010 08:41 PM
Ive also used mineral pirits to clean up old Disston saws myself. I started with a paint scraper, the single razor balde type, and scraped all the rust i could get off with that. Then using the mineral spirits and 220 sandpaper, being careful to not sand too hard where the etching is, and then moved up to some 320. I finish the blade off wth a good coat of paste wax. As stated above take the handles off first it just makes it a bit easier. Also if you are interested in identifying the saws google “Disstonian Institute” its got everything one needs to know about their tools. Good luck and post some pics if you can, id love to check em out.
Ive heard good things about evapo-rust, never used it myself, i think the only way to get it is to order online.
View Dennisgrosen's profile
Dennisgrosen
10880 posts in 3082 days
#6 posted 06-14-2010 08:44 PM
there is allso the possibilytess to use either electrolyse or citric accid
to remove rust with
you can read more about it here
http://www.wkfinetools.com/contrib/jThompson/howTo/rust_CitricAcid/rust_CitricAcid1.asp
http://homepage.mac.com/estuary1/estuary/PhotoAlbum4.html
hope it will helps you
good luck with your tools
take care
Dennis
View edgarO's profile
edgarO
68 posts in 2872 days
#7 posted 06-14-2010 08:52 PM
I saw evaporust on Cool tools on diy network and the things they got rust off were amazing. you dont even have to wear glove as it is not caustic.
heavyelectrician
#8 posted 06-14-2010 09:13 PM
chrisstef, i will get some photo’s and put them on, before and after. just with my current job i can’t get out to the shop as much as i would like. so it might be a little bit before i’m done. but i will definetly let you know. one of them i had to replace the handle because it was half gone. i was able to save the medallion that was originally there. i made the new handle out of a piece of maple i had in the scrap bin. first time i ever had to make a handle before. it works, feels and looks pretty good but i want to redo it better.
Thanks for all the extra info you guys are giving, i’m learning alot more than i thought i would.
View bigjoe4265's profile
bigjoe4265
52 posts in 2899 days
#9 posted 06-14-2010 09:46 PM
Yes, Evapo-rust works quite well and goes a long way. I get it at HF in the automotive section for around $17/gal (concentrated, treats 300 lbs. of steel). It can blacken or sort of gun blue steel, but I would imagine that could probably be removed with others suggestions/methods.
Bigjoe
View swirt's profile
swirt
2648 posts in 2939 days
#10 posted 06-14-2010 10:50 PM
I follow this method
http://www.vintagesaws.com/cgi-bin/frameset.cgi?left=main&right=/library/library.html
But if I am doing it indoors I use wd-40 instead of mineral spirits.
View PurpLev's profile
PurpLev
8534 posts in 3616 days
#11 posted 06-14-2010 11:15 PM
I’ll second (or third.. or whatever number we’re at) the Evaorust for smaller tools/blades/saws. you can find it at any automotive store. you can see what it did to my #6 plane in this blog with minimal to no labor: http://lumberjocks.com/PurpLev/blog/10604
good luck
View hairy's profile
hairy
2656 posts in 3499 days
#12 posted 06-14-2010 11:41 PM
Take a peek at this:
http://www.disstonianinstitute.com/
By the way, Front Royal is a great place!
-- My reality check bounced...
View mvflaim's profile
mvflaim
189 posts in 3058 days
#13 posted 06-15-2010 01:31 AM
Go here and look around. http://www.badaxetoolworks.com/cleaning-a-sawplate.html
He is a premier hand saw restorer and maker.
