Another Plea for Help!!
Forum topic by FunnelStudio posted 06-14-2010 05:43 PM 1393 views 0 times favorited 10 replies Add to Favorites Watch
View FunnelStudio's profile
FunnelStudio
30 posts in 3223 days
06-14-2010 05:43 PM
Topic tags/keywords: question
Hey everybody!
I have a stained glass window frame job I am quoting out, and after getting a picture from the customer, I am a little stumped on a bevel.
The size of the frame is a 75.5” outside diameter oval (that measurement if the longest part), and the stock is 1 5/8” x 2 5/8”, and as you can see in this picture, there is a slight bevel on one side.
I’m a little baffled on the best way to go about it, and my guess is there is probably a router/shaper bit (I only have routers, however…) that would do the job, but I’m not 100% on that, so I turn it over to you, dear woodworkers. Anyone have any ideas?
-- -Shaun M. Baer, http://www.craftedphiladelphia.com
10 replies so far
View sandt38's profile
sandt38
166 posts in 2813 days
#1 posted 06-14-2010 05:58 PM
I am thinking maybe a shaker style vertical raised panel bit
http://woodworker.com/vertical-raised-panel-bit-mssu-916-283.asp?utm_source=google&utm_medium=feed
Does that look about right?
-- Got Wood? --- Somewhere along the way the people in Washington forgot that they are there to represent the people, not to rule them.
FunnelStudio
#2 posted 06-14-2010 06:30 PM
Well, almost. A problem I forgot to mention is that the radius is inside the diameter, so if I used a vertical bit, the router would have to run inside the frame. Does that make sense?
sandt38
#3 posted 06-14-2010 08:04 PM
Yes, I understand. So you would need something with a guide bearing instead of the bit like I posted.
http://www.woodcraft.com/Product/2020264/21322/Shaker-Profile-Raised-Panel-Bit-with-3-Bearings.aspx?refcode=05INFROO
How about that?
View Gene Howe's profile
Gene Howe
10126 posts in 3334 days
#4 posted 06-14-2010 08:10 PM
Using a table mounter router, running the Shaker pit should not pose a problem as long as you can reliably vary the depth of cut.
How critical is it that you achieve the exact angle?
Here is a link to some chamfer bits. 15 degree is the least steep angle.
Chamfer
I would try to find a bit with a bearing that can be interchanged. That way you can take incrementally deep cuts.
It’s safer!
Gene Howe
#5 posted 06-14-2010 08:14 PM
sandt38’s suggestion is right on. Just get another bearing or two to limit your depth.
View allthunbs's profile
allthunbs
25 posts in 2824 days
#6 posted 06-16-2010 01:33 PM
Hi Shaun:
A pair of skis on your router might be just the trick. You can set one ski slightly shorter than the other and carve the angle in stages. I would do all the other faces first though. You’ll have to practice the operation. I’m just wondering how it would be to add a guide point (like a resaw fence on a bandsaw) to the inside of one of the skis. This would allow you to follow the curve of the ellipse. If the slope is to the outside, use the guide point on the outside. If it is on the inside set it on the inside. Use flat-board skis. P.S. won’t work worth a d* with PC routers. Too much flex in the rods.
View Moron's profile
Moron
5032 posts in 3799 days
#7 posted 06-16-2010 01:44 PM
cut the stock square, then route/shape the ogee, then dado out that rabbet, then cut the bevel on the rabbet with a TS. Then flip the piece with routed/ogee facing up…............then cut the last long bevel on the TS…..................sand and done.
116906 posts in 3483 days
#8 posted 06-16-2010 06:10 PM
I like to buy quality router bits but I find some of the inexpensive sets are great to have .
Here is a set i bought that has 80 router bits for $90 including shipping.
http://cgi.ebay.com/80pc-1-2-Shank-Tungsten-Carbide-Router-Bit-Set-3-Blade-/170500815835?cmd=ViewItem&pt=Routers_Bits&hash=item27b2a3fbdb
allthunbs
#9 posted 06-16-2010 08:55 PM
Hi Shawn:
Thinking this through some more. Start on the high side of the angle and cut completely around the oval, then slide the router down the rods slightly and redo the cut. Continue this until all your angle is cut. Set the rods of the skis to the angle you want with the finish cut height on the lower ski and the edge of the guide point.
Moron
#10 posted 06-17-2010 05:52 AM
cheap brand new inexpensive set or single cheap router bit = rpg in waiting and/or ied
only 50 choices of how to be blinded for 90.95 plus minus a decimal point
without exception and without prejeduce, they look nice looking back at you but in application they are welded/brazed/ very pretty time bombs.
