Can someone help me calculate 2x4 weight please?
Forum topic by FancyShoes posted 09-10-2016 10:46 PM 1377 views 0 times favorited 3 replies Add to Favorites Watch
View FancyShoes's profile
FancyShoes
555 posts in 1509 days
09-10-2016 10:46 PM
Thanks for the help!
I build a lumber rack to get my lumber off the floor. I went 20” long then added a brace, about 47 degree angle down to the studs. And have them supirted by the 1.5” piece at the stud as well. I have them ever other stud, so that is 32” on center apart.
I want the lumber off the floor so I am trying by experiment.. I really dont want to walk out to them on the floor once again.
3 replies so far
View dawsonbob's profile
dawsonbob
3031 posts in 1900 days
#1 posted 09-10-2016 11:03 PM
View Gene Howe's profile
Gene Howe
10900 posts in 3573 days
#2 posted 09-10-2016 11:27 PM
My racks are like yours and mounted almost the same way. Every other one has a pocket screw on each side, into the stud. Mine are loaded way heavier than yours and have never failed.
View MadMark's profile
MadMark
979 posts in 1597 days
#3 posted 09-10-2016 11:37 PM
The USDA ‘Wood handbook – wood as an engineering material’ says ‘it depends’ on the moisture % – which changes over time. Pine density is around 0.32-0.52 depending on overdry from green.
Estimate the bf, divide by 12 for cu foot and multiply cu ft by 62.42796 lbs / cu ft for max weight if wood is 100% water. Divide by two for greenwood or three for overdry pine. Other species will have different values.
Sorry, sometimes simple problems aren’t.
M
