TIP: 1" Extra Cut On Mitre Saw
Forum topic by Rick posted 06-14-2010 07:00 AM 1622 views 0 times favorited 15 replies Add to Favorites Watch
View Rick's profile
Rick
9596 posts in 3030 days
06-14-2010 07:00 AM
Topic tags/keywords: tip jig trick all wood miter saw cutting traditional
Just a Quick Little Tip that might come in Handy one day.
I got this Picture somewhere a few Months ago. I tried it on my Non Slider, Delta 10” Mitre Saw. Instead of the 2 pieces of Plwood as shown I used a piece of 2”x8” Cedar I had lying around. So that raised the Table (cut) by 1-1/2”.
In MY case it increased the Cut by 1-1/4”, from 6-1/4” to 7-1/2”. That moved the Cut Capicity on a 3/4” Board up to a 1”X8” (3/4”x 7-1/2”). Obviously this happens when the Centre Point of the Blade is Exactly Horizontal to the Back Hinge of the Arm that Moves the Blade Up and Down. No. I don’t see this as a “Safety Violation” ...LOL…
I willl be buying a New Makita 10” LS1016L which will do a 12” Cut in 2” Material at 90 Degrees, BUT I will be keeping my Delta also and perhaps setting it up for Specific Functions.
Hope this might be of some value to other LJ’ers.
Rick
Increase Cut Width
-- LIFE is what happens when you're planning on doing Other Things!
15 replies so far
117091 posts in 3574 days
#1 posted 06-14-2010 07:05 AM
Cool idea
View Rick's profile
Rick
#2 posted 06-14-2010 07:09 AM
Jim:
I just Posted this 4 Minutes ago and it’s 1:05 AM Up here! Do you take a Lap Top To Bed with you? ...LOL..
Thank you Kind Sir!!
Rick
View LarryDNJR's profile
LarryDNJR
209 posts in 3091 days
#3 posted 06-14-2010 07:41 AM
I think he has his laptop with him 24/7 I see him comment on almost every post on LJ. :)
-- ~Larry Columbus, OH
View crank49's profile
crank49
4030 posts in 2968 days
#4 posted 06-14-2010 07:53 AM
Thanks Rick.
I got my Delta in 1998 and wished I had waited for the sliders ever since.
That extra inch will be handy because I just got a table saw and don’t see a new miter saw in the near future.
View scrappy's profile
scrappy
3507 posts in 3427 days
#5 posted 06-14-2010 08:26 AM
Works great for the thinner (less then 1 1/2) material. All you loose is the ability to cut thicker things like 4×4.
Will come in handy. Thanks for the tip.
Scrappy
-- Scrap Wood's the best...the projects are smaller, and so is the mess!
View Viking's profile
Viking
880 posts in 3192 days
#6 posted 06-14-2010 11:10 AM
Rick;
Great Idea! Thanks for sharing. Had a situation a couple of weeks ago that this would have solved.
-- Rick Gustafson - Lost Creek Ranch - Colorado County, Texas
13603 posts in 3338 days
#7 posted 06-14-2010 11:32 AM
i do this for 1×6 decking ,
makes a big difference on older chop saws .
good tip .
View TheWoodsmith's profile
TheWoodsmith
108 posts in 2917 days
#8 posted 06-14-2010 12:30 PM
Cool tip, Next time that issue arises (which will be soon with my little saw) i will certainly give it a go!
-- I know its around here somewhere...
View GMman's profile
GMman
3902 posts in 3694 days
#9 posted 06-14-2010 01:40 PM
Rick good tip.
Jim well making comments on all post is his life that is all he can do.
View CyBorge's profile
CyBorge
79 posts in 3172 days
#10 posted 06-14-2010 04:15 PM
The picture doesn’t show any support for the cutoff piece. Seems like this could be dangerous in certain cases without providing that support.
-- "How can I be lost if I've got nowhere to go?"
View Rick's profile
Rick
#11 posted 06-15-2010 10:42 AM
CyBorge:
Yes. You are right about that. I believe the Picture is just for Clarity. As I said earlier i don’t see this as a “Safety Violation”. When I tried it out my 2 pieces of 2×6 were on both sides of the cut (Blade), naturally.
Rick
View Cato's profile
Cato
701 posts in 3309 days
#12 posted 06-15-2010 01:20 PM
Rick, if you are coming from a non slider to the Makita LS1016L you will be amazed how nice the saw is.
I have had mine for a few months now and enjoy using it a lot.
CyBorge
#13 posted 06-15-2010 04:20 PM
I agree, Rick. I only brought it up to make sure the point was made somewhere. It’s pretty easy to blindly follow a picture without thinking it through.
Along similar lines, I suppose it should also be said to not use too thick of a platform so that your work piece isn’t properly supported by the fence.
View Abbott's profile
Abbott
2570 posts in 3301 days
#14 posted 06-15-2010 04:27 PM
Good idea Rick.
-- Ohh mann...pancakes and boobies...I'll bet that's what Heaven is like! ♣ ♣ ♣ ♣
View Rick's profile
Rick
#15 posted 06-16-2010 05:45 AM
Cato:
Thank you. Nice to hear. It’s always a bit agonizing when buying a new piece of equipment. It was a toss up between the Makita or the Bosch. After looking at them both and playing with them, it just seemed to me that the Makita was a more”Solid Saw” especially with the “Double Slide” back rails.
CyBorge: Thank you?
