Wedged Tenon Input
Forum topic by Ken Reidy posted 06-13-2010 07:19 AM 833 views 0 times favorited 1 reply Add to Favorites Watch
View Ken Reidy's profile
Ken Reidy
2 posts in 2880 days
06-13-2010 07:19 AM
Hi All,
I am building 3 gates with frame and panel construction and want to use a wedge in the tenons. The through mortises are 5 1/2” deep and the tenons are 5/8” thick by 1 3/4” wide. Hopefully the fit should be tight without them but for extra security, I though a wedge might be appropriate. What is the ration of length to width for the cut out in the tenon? I am assuming that the wedge should be of similar configuration only a little longer. I seem to remember hearing that a hole should be drilled at the base of the wedge cut out in the tenon to prevent splitting.
Any input would be humbly appreciated!
Many Thanks,
Ken
1 reply so far
117063 posts in 3542 days
#1 posted 06-13-2010 07:23 AM
It seems to me that wedged tenons would get it the way on a gate unless you mean pinned tenons.
