butt hinge with stop?
Forum topic by Mike posted 06-13-2010 02:57 AM 3633 views 0 times favorited 6 replies Add to Favorites Watch
View Mike's profile
Mike
93 posts in 3187 days
06-13-2010 02:57 AM
Need to find a source for good quality brass hinges that dosn’t break the bank.
I need a hinge to work on a jewlery box. I want it to mortise into the top of the box and the inside of the lid.
The top edge of the box is 1/4” wide and 8” long the lid has 3/8” wide area to mortise to and is 3/8” thick.
I like the look of the Brusso hinges but the JB 102 is a little wide for the 1/4” sides. Also the cheapest I have found them is $20.95 at toolsforworkingwood.com .
Any ideas on hinges I mite try would be appreciated.
Thanks
-- Mike, Cantral Oregon
117114 posts in 3599 days
#1 posted 06-13-2010 04:58 AM
Here’s the best place I know
http://www.horton-brasses.com/
View lew's profile
lew
12100 posts in 3778 days
#2 posted 06-13-2010 04:07 PM
These folks might have something:
http://www.cshardware.com/
View Mike's profile
Mike
#3 posted 06-14-2010 12:14 AM
Thanks guys
I looked at Horton already and I just went to csh. Didn’t see what I needed but I will call on Monday and ck with them.
Been playing with making wooden hinges. I can get them small enough and black walnut is strong enough but I had a little catch with holes not quite straight in both sides so I need to get a better clamping systom on my drill press.
I will try agean tonight and see if I can make it work. May need to get a stiffer drill bit or a drill press with less slop. I am only using 1/8 rod for the pin and drilled with a bit that miced at .127 for a nice tight hinge. Very little room for error.
View lew's profile
lew
#4 posted 06-14-2010 03:07 AM
Here is another place that might have something:
http://www.paxtonhardware.com/
View Orion's profile
Orion
15 posts in 3113 days
#5 posted 06-14-2010 07:54 PM
We, meaning Horton, don’t make stop hinges. Is this for a box? Lee Valley carries Brusso’s box hinge with a stop-but it is a back mount-meaning not a traditional butt hinge.
Brusso makes some nice ones here, (they should be available through a distributor): http://www.brusso.com/Product_categories/BoxHinges/boxhinges.php
-- Horton Brasses Inc, makers of fine reproduction brass and iron hardware
View Mike's profile
Mike
#6 posted 06-18-2010 06:47 PM
Thanks for the response guys. I Have been to the sites you suggested and it looks like Brusso has the only stop hinge I can find. I may have to spend the money but I am trying the wood hinge idea first.
Thanks
