Wow! Nova drill press
Forum topic by Woodchuck2010 posted 09-08-2016 02:17 PM 1207 views 0 times favorited 18 replies Add to Favorites Watch
View Woodchuck2010's profile
Woodchuck2010
722 posts in 1054 days
09-08-2016 02:17 PM
Hefty price , but very high tech. How come no blue tooth? hahaha
https://youtu.be/6PvDExhAOC8
-- Chuck, Michigan,
18 replies so far
View JAAune's profile
JAAune
1850 posts in 2513 days
#1 posted 09-08-2016 03:21 PM
All that money and it still has that crummy table tilt mechanism that every other drill press uses? I have had many issues trying to keep drill press tables from getting knocked out of alignment since they all rely upon a single bolt and friction between small surfaces to keep the table in place. It’s annoying to have to make adjustments every time I need to drill a precise hole in a jig.
The exception is my ancient Buffalo which locks around a 4” diameter hub. That will not get bumped out of place if someone bumps the table too hard.
View GR8HUNTER's profile
GR8HUNTER
5090 posts in 909 days
#2 posted 09-08-2016 03:43 PM
very neat ….. but for that much money ….....mines fine …......LMAO
Woodchuck2010
#3 posted 09-08-2016 04:07 PM
- GR8HUNTER
Yup!
-- Chuck, Michigan,
View JoeinGa's profile
JoeinGa
7739 posts in 2203 days
#4 posted 09-08-2016 04:53 PM
Hmmm, at that price, if I’m not gonna get kissed, I at LEAST want a cupholder !
View Randy Woodworker's profile
Randy Woodworker
68 posts in 2525 days
#5 posted 09-09-2016 02:16 AM
I’ve got about $600 into my VS drill press. I’ve changed the press from the one shown in the video to a better delta (17-965) with 4.75” stroke. I just moved the 3-phase motor and electronics over to that press and sold the other one.
Variable Speed Drill Press
Woodchuck2010
#6 posted 09-09-2016 04:07 AM
I ve got about $600 into my VS drill press. I ve changed the press from the one shown in the video to a better delta (17-965) with 4.75” stroke. I just moved the 3-phase motor and electronics over to that press and sold the other one.
- Randy Woodworker
That is very cool. Impressive work. I’m in $399 into my WEN drill press. lol
-- Chuck, Michigan,
View DirtyMike's profile
DirtyMike
637 posts in 1098 days
#7 posted 09-09-2016 04:10 AM
How is your wen holding up chuck? Any complaints?
Woodchuck2010
#8 posted 09-09-2016 04:34 AM
- DirtyMike
It’s doing absolutely great. Thank you. I’m very glad I bought it. I did add a table to it.
-- Chuck, Michigan,
Randy Woodworker
#9 posted 09-09-2016 01:33 PM
Great price! Never heard of Wen. Must check them out. Far cry from the General International offering of 1500 or so.
GR8HUNTER
#10 posted 09-09-2016 03:28 PM
Hi Chuck , what is digital readout used for on your wen drill press
View Gene Howe's profile
Gene Howe
11056 posts in 3625 days
#11 posted 09-09-2016 03:39 PM
The new Shopsmith PowerPro has the exact same power unit. In the drill press configuration, it operates just like the one shown.
Don’t know how old that video is but, the Shopsmith model has been available for several years.
Woodchuck2010
#12 posted 09-09-2016 04:41 PM
- GR8HUNTER
It’s used for the variable speed function.
-- Chuck, Michigan,
View Woodknack's profile (online now)
Woodknack
12425 posts in 2576 days
#13 posted 09-09-2016 07:17 PM
Don t know how old that video is …
- Gene Howe
According to the date, 15 days old.
Thoughts…
-The speed knob is dinky and requires many rotations from lowest to highest speed.
-Either that guy is really tall or the press is really short #achingback
-The drill bit selector is a lot of menus, I doubt anyone will use that more than a couple times except to show it off.
-No mention of a memory function in the video or on the website but according to the manual, F keys save speed (only) presets; I can’t find a way to save other settings. The analog table limits the usefulness of a digital depth stop.
-It seems to be a plain drill press with fancy digital features. What I would rather see is a better drill press with better bearings, more precision, and a way to retain the arbor so it doesn’t drop out if using the drill press for sanding.
I’m not really familiar with variable speed drill presses from other companies so maybe in comparison it’s an improvement?
View Lee's profile
126 posts in 1074 days
#14 posted 09-09-2016 07:39 PM
All that money and it still has that crummy table tilt mechanism that every other drill press uses? I have had many issues trying to keep drill press tables from getting knocked out of alignment since they all rely upon a single bolt and friction between small surfaces to keep the table in place. It s annoying to have to make adjustments every time I need to drill a precise hole in a jig.
- JAAune
I had the same problem keeping my drill press table perpendicular to the bit, so I got it all aligned and drilled and tapped a hole in the clamping support for a set screw, if I need to tilt it just remove the set screw and loosen the clamp, when going back to flat, line up the set screw hole and replace it, dead on again.
-- Colombia Custom Woodworking
woodbutcherbynight
5669 posts in 2605 days
#15 posted 09-10-2016 03:34 AM
Hmmm, at that price, if I m not gonna get kissed, I at LEAST want a cupholder !
- JoeinGa
Exactly, and I am not going to be happy one day when it does not work because it wants an update. LOL
Think I will stick with the obsolete JET and call it a day.
