Buffing out a table top
Forum topic by doninvegas posted 06-12-2010 01:32 AM 7518 views 1 time favorited 9 replies Add to Favorites Watch
View doninvegas's profile
doninvegas
334 posts in 2959 days
06-12-2010 01:32 AM
I am doing a refinishing job and I just got the last coat of semi gloss GF High Performance on it. I have been sanding very lightly with a 400 grit sanding cloth between coats but I want to buff out this last coat to make it smooth without loosing the sheen. I don’t have access to the good 2000 or 4000 sanding pads so I need to get something maybe from an auto parts store. Can I use some high grit wet-dry sanding sheets? And how do get it even?
Thanks for your help with this. I charged the customer $700 and I want the table top to be very smooth.
-- "Courage is being scared to death -- but saddling up anyway."
9 replies so far
117160 posts in 3629 days
#1 posted 06-12-2010 02:28 AM
How about some extra fine buffing compound.
View live4ever's profile
live4ever
983 posts in 3062 days
#2 posted 06-12-2010 03:24 AM
Wet sand up to 800 or 1200. Use a sanding block to keep things even.
Then for the final buffing, you could get some Meguiar’s polishing pads and polishing compound from the auto parts store…
View swirt's profile
swirt
2813 posts in 3024 days
#3 posted 06-12-2010 03:25 AM
There was a great article in Fine Woodworking a month or two back on this. I’ll see if I can go dig it out.
View davidroberts's profile
davidroberts
1027 posts in 3538 days
#4 posted 06-12-2010 03:54 AM
This video from our own Steve in Marin may help.
http://lumberjocks.com/Stevinmarin/blog/16066
-- Better woodworking through old hand tools.
View bill1352's profile
bill1352
130 posts in 3173 days
#5 posted 06-12-2010 04:17 AM
I use micro mesh disks. woodcraft has 5” & Peachtree has 6” disks. woodcraft has a video with Charles using the micro mesh disks. I’m tellin ya there is nothing easier. a little soapy water in a spray bottle and an orbital sander or polisher and 30 mins later its like glass. I use a car polisher from harbor freight, costs $17.00 but you need to get self stick velcro for the polisher pad. The disks are about $20. you dont want the polisher running over 3500rpm, 2500 is perfect. I use the polisher because a variable speed sander has dust collection or in this case water collection, not a good thing.
-- Keep Your Stick On The Ice
View thatwoodworkingguy's profile
thatwoodworkingguy
375 posts in 2981 days
#6 posted 06-12-2010 04:20 AM
Steel wool always does the job for me when I tackle this part of the finishing process
-- thatwoodworkingguy.com ~Eagle America~ ~Woodcraft~
doninvegas
#7 posted 06-13-2010 01:52 AM
OK great suguestions. I used GF High Performance which is water based. How long would let it cure before buffing? I don’t want to reactivate the finish with water. I got the last coat on yesterday and I would like to buff it next Sat.
View pmayer's profile
pmayer
1028 posts in 3117 days
#8 posted 06-13-2010 02:02 AM
Buff out the final coat with the back of the sand paper. it has enough abrasive quality to do a nice job on this. The texture of most sand paper backing is about the equivalent to 2000 grit, and since you have sanded between coats I would think this would be adequate.
Waiting a week is decent since you are in Vegas where you don’t have much humidity to contend with. In MN right now, I would probably wait 2 weeks if I could.
View Kelly's profile
Kelly
2044 posts in 2996 days
#9 posted 06-13-2010 03:54 AM
All my 2000 grit is wet-or-dry from auto parts stores.
I also use powders and polishing pads, which are also available from auto parts stores (I put them in labeled one gallon Zip Lock bags so I know which pad was used for pumice, which for rotten stone, which for baking powder and which for one was used for cerium oxide)
Just for reference, I use a Porter Cable random orbit, variable speed sander-polisher and a hook and loop backer pad for quick changes.
Oddly enough, I haven’t had a lot of luck getting to a mirror gloss finish with 2000 grit. I usually finish with cerium oxide or plastic polish from an auto parts outfit. Today, I rattled canned a friends hood (his idea, I told him about my HVLP, but he always knows better). It made hell look good, until I polished with pumice, then cerium oxide.
A few months ago, I did a oak table and chairs and finished with poly. I don’t have a finishing room these days and the finish was applied by brush, so it was far from a sprayed finish. I did the final with 0000 steel wool and wax and it turned out glass smooth (I snuck up on that one with pumice and rotten stone).
