*When to stop* Hand planing?
Forum topic by HillWilly posted 09-06-2016 11:00 PM 951 views 0 times favorited 6 replies Add to Favorites Watch
View HillWilly's profile
HillWilly
54 posts in 2252 days
09-06-2016 11:00 PM
Topic tags/keywords: hand plane planing hand tools hand planing stanley bailey question
Howdee Ljox
I’ve got old, gray roughcut [hemlock??] 20 foot 2×4’s that I am building my bench with. I am leaving the weathered look for aged affect
I am planing one face of eight 36 inch pieces to join for the legs. These will be joined into 4×4’s.
I have planed the twists and high spots out. I have them close enough so light is barely visible between them.
My skill level and equipment aren’t the best so My Question is…...
How do I know when to stop planing. when is it good enough!!!!!
-- ...and whether or not it is clear to us, no doubt the universe is unfolding as it should...DESIDERATA...Max Ehrmann
View Aj2's profile
Aj2
1716 posts in 1942 days
#1 posted 09-07-2016 12:35 AM
Can you squeeze the joint closed with your hands?Then your done.
If you can still see light find the last high spots.
Aj
-- Aj
HillWilly
#2 posted 09-07-2016 02:41 AM
Thanx AJ, but you have lead me to electric planer ish perfection, but alas my skill level and equipment don’t seem to allow me that quality of work.
I guess my question is …...How much perfection is considered ok for amature hand planing. There is no rocking, and mear slivers of light visable. Any gaps probably would not allow a dollar bill. I have used winding sticks and straight edges and squares. Will this be sufficient to justify a glue joint!
My problem here is I have nothing to compare my work to….What will work, and what wont!
View Aj2's profile
Aj2
#3 posted 09-07-2016 04:04 AM
I have handplanes I also have a jointer. Sorry my answer was not helpful.
I always try to share my experience strength and hope.
Sometimes I do parrot information but only if it’s good.
Good luck with your project.
Aj
-- Aj
View nightguy's profile
nightguy
213 posts in 806 days
#4 posted 09-07-2016 05:20 AM
Thanx AJ, but you have lead me to electric planer ish perfection, but alas my skill level and equipment don t seem to allow me that quality of work.
- HillWilly
If your gaps are that tight you are good to go!!
View rwe2156's profile
rwe2156
3090 posts in 1624 days
#5 posted 09-07-2016 01:23 PM
For something like this, if the gaps clamp out, glue them up.
Then re flatten and square up after you got your 4×4.
View HokieKen's profile
HokieKen
6266 posts in 1282 days
#6 posted 09-07-2016 02:06 PM
Sounds good enough to me. Do a “dry” clamp up, if the gaps close up, you’re good to go.
-- Kenny, SW VA, Go Hokies!!!
