Delta 36-659 arbor nut assembly
Forum topic by Luthierman posted 09-06-2016 10:24 PM 1279 views 0 times favorited 9 replies Add to Favorites Watch
View Luthierman's profile
Luthierman
221 posts in 1112 days
09-06-2016 10:24 PM
So these are made of unobtanium. Apparently they no longer exist. Anyone know of a comparable replacement assembly that will work on the right tilt unisaw? I don’t have one on the saw I just got. Phooey.
-- Jesse, West Lafayette, Indiana
9 replies so far
View MrUnix's profile
MrUnix
6766 posts in 2224 days
#1 posted 09-06-2016 10:35 PM
You just need the arbor nut?
Sawcenter claims to have them. And I’m sure you could find several over at OWWM if you asked nicely :)
Luthierman
#2 posted 09-06-2016 10:40 PM
Awesome. I really need the washer too. I have the flange that rests against the arbor. I will look through that site. Thanks Brad. That website didn’t come up in my searches.
MrUnix
#3 posted 09-06-2016 11:00 PM
Not sure what you mean by you have the flange but need a washer? The only thing you need is the nut and a flange washer. The flange washers can be found pretty easily (like here). If you search for the part number you can usually find stuff that doesn’t pop up with a generic search. So a search for the nut (“902-01-200-9848”) and flange (“422-04-103-5001”) turn up quite a few sources.
PS: Did you ever date that machine via the serial number?
Luthierman
#4 posted 09-06-2016 11:15 PM
Thanks again. I am using some incorrect terminology. I need the flange washer. The rest of the arbor is intact.
I did date the machine. Made back in ‘74. I also got the motor up and running. VFDs are absolutely amazing. One thing that may be noteworthy though, the motor shudders a little bit at certain frequencies. It doesn’t really bother me though because I don’t see that I would ever need to run the motor as slow as when the shuddering occurs. From what I have read, some motor and VFD combinations are prone to that kind of behavior. I am not sure, but I think I can set some parameters that may alleviate that symptom.
View Austinpeay's profile
Austinpeay
28 posts in 385 days
#5 posted 07-02-2017 10:46 AM
If you have not found one yet – I have three new ones available.
Austinpeay
#6 posted 07-03-2017 08:35 PM
If you are still looking for the 36-659, I have three of them, new in package.
View cyclist2918's profile
cyclist2918
2 posts in 1547 days
#7 posted 07-18-2017 07:05 PM
- Austinpeay
Austinpeay,
If you still have any of those available, I’m interested. I have a Delta contractor’s saw that has an aftermarket nut and washer, but it’s too large to allow the installation of a dado blade.
runswithscissors
2766 posts in 2050 days
#8 posted 07-19-2017 04:56 AM
You can make your own flange washer. It’s important to have the face that goes against the blade dished. A flat washer will distort the blade when you tighten the nut. The diameter of the washer must be equal to the arbor flange. Make the dish shape by using a small (4”—4.5”) angle grinder tilted so that the edge of the grinder disk is contacting only the center portion of the washer. As far as I can remember I made my own washer out of 3/16” mild steel plate. The dished out part doesn’t need to go very deep—just enough so it won’t distort the blade when the nut is tightened. I left about 1/4” or narrower perimeter not dished.
Although I eventually acquired a (used) official washer-flange, I still use the homemade one.
View Joesulli's profile
Joesulli
1 post in 102 days
#9 posted 03-10-2018 10:26 PM
- Austinpeay
