Drawer *slightly* too wide for frame -- Fix?
Forum topic by Jakl posted 09-06-2016 12:45 PM 895 views 0 times favorited 7 replies Add to Favorites Watch
View Jakl's profile
Jakl
5 posts in 625 days
09-06-2016 12:45 PM
Building a changing table for my daughter that is on the way and got mostly done with the project. I measured the interior width incorrectly and each of my drawers are about 3/32 too wide for the opening. I am planning on using full-length soft close drawer slides on this piece so I need 1/2” on each side for the slides to fit.
The sides of the drawers are 1×8 dimensional pine.
I have a 6” jointer but there is a roll pin that is for the guard cover that prevents me from putting this whole piece through.
I had considered the following:
Tall router bit on my router table and adjust the fence to take 1/32 off at a time. Problem is the slides are 1.5” tall and the tallest bit I have is a pattern bit and even with the bearings removed it is only 1.25”.
or
Clamp the drawer (its roughly 18×37”) in my cross cut sled (just barely fits) and take off a little at a time on the table saw.
Are there any other options I am not considering? I do not own a shoulder plane, but not sure that would be well suited to a 1.5” wide cut path anyway.
Here is a picture of the rough layout of how the project looks. Its not constructed EXACTLY like this but for the considerations on drawer mounting the picture accurately portrays how it will go.
7 replies so far
View Nubsnstubs's profile
Nubsnstubs
1286 posts in 1727 days
#1 posted 09-06-2016 12:56 PM
Set your table saw fence at .045”, raise the blade to 1 1/2”+, and run it through both sides. Done. Reinstall the slides, and you’re in business again….........Jerry (in Tucson)
View JoeinGa's profile
JoeinGa
7736 posts in 2004 days
#2 posted 09-06-2016 01:08 PM
If all you need is clearance for the slides, how bout use a router and cut a channel on each side of the drawer for the slides to sit in? Rout the area I show in red on both sides.
View dhazelton's profile
dhazelton
2767 posts in 2294 days
#3 posted 09-06-2016 01:09 PM
What that man said – you only need to remove material where the slides go, not the entire side of the box.
JoeinGa
#4 posted 09-06-2016 01:09 PM
Oh and WELCOME to LJs !
View HokieKen's profile
HokieKen
4990 posts in 1135 days
#5 posted 09-06-2016 01:11 PM
Yep, Joe hit the nail on the head. Just route a 3/32” deep rabbet for the drawer slides.
-- Kenny, SW VA, Go Hokies!!!
View pintodeluxe's profile
pintodeluxe
5657 posts in 2810 days
#6 posted 09-06-2016 04:42 PM
Am I missing something here? Hand plane?
Depending on the drawer joinery, you can get some pretty nasty tearout making this cut on a jointer.
The traditional way to tune drawer fit is with a hand plane. I am a power tool guy through and through, but this is one task I thoroughly enjoy picking up a low angle block plane. If you don’t have one, invest in one now. You will reach for it on countless occasions.
Certainly the tablesaw (sacrificial fence) or router could get the job done too.
HokieKen
#7 posted 09-06-2016 06:01 PM
I generally agree with Willie on tuning fit with a block plane. But, 3/32 might be a bit more material than I’d want to remove with one. Would certainly do the job though.
